No spark on my work truck.. URGENT PLEASE!
Old Sep 9, 2007 | 02:08 PM
85ghettorunner's Avatar
Was driving my 86 4 runner (stock 22r, fuel injected, new/good plug,wires, and cap) last night when it cut out on me. I now have NO spark. Can someone PLEASE give me the quick diagnosis steps for finding the problematic link in my ignition system?
IE: Which is the ignition fuse, and relay.
How do i determine if the coil is 1. gettting power 2. the coil is good?
I am desperate and need the truck for work tomorrow, so any help would be greatly appriciated.
Old Sep 9, 2007 | 08:04 PM
FOCUSHERE's Avatar
i alwasy stick a screw driver in the wires and have a buddy crank it and see if it arks on a ground then go from there
Old Sep 9, 2007 | 08:11 PM
ozziesironmanoffroad's Avatar
are dash lights coming on or is the whole system dead as a doornail?
Old Sep 10, 2007 | 09:17 AM
dcg9381's Avatar
Advice would be to beg borrow or steal a factory service manual - they used to have them up over at 4x4wire.com.
Coil can be tested.. To see if it's getting power, with the ignition on, verify you have 12v the terminals and a ground. The coil gets charged when switched to ground, so it should have 12v with the ignition on.
Check the signal generator in your distributor - make sure the distributor is turing, there are two wires coming out of it.. It should generate AC voltage when you crank over the truck.
Diagnosing the ECU and ignitor are harder.. Need a manual.
Old Sep 10, 2007 | 10:19 AM
thook's Avatar
Still do.....just click on the linky poo. (1993 FSM)
http://www.4x4wire.com/forums/showfl...5&o=14&fpart=1
Then, there's this also...
http://www.ncttora.com/fsm/index.html
Charecter1
Nov 6, 2023 10:08 AM
MO transplant
Apr 23, 2023 11:58 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
smiley52
Jul 11, 2015 05:16 AM
karbin
Jul 5, 2015 11:37 PM
