No Power to fuse box. Inside the truck
Old Aug 18, 2017 | 12:21 PM
Theadonutbear's Avatar
I have aa 2 door rrwd. 94 toyota pick. Up. I. Started it. Tthen the whole tthing shut off. I. Thought it was the battery so i replaced the battery i thought it was the starter relay so i replaced it upon futher trying to figure it out. I dont have power to the radio. Air conditioning none of the lights. And nothing in the gauge cluster works and no i am not 100% positive. But i have no power. To the fuse box under the dash on the driver side
Old Aug 18, 2017 | 01:36 PM
wyoming9's Avatar
Red face
Time to break out the Meter only real world numbers will let us help you
Old Aug 18, 2017 | 02:06 PM
scope103's Avatar
Using this page of the manual http://web.archive.org/web/201204170.../2powersou.pdf
you can work out which circuits have power, and therefore, whether you have a fuse, wire, or ignition switch problem.
Yes, you obviously need one of those $7 multimeters to look for your problem. A tiny fraction of what you've already wasted on an unnecessary battery and starter relay.
Old Aug 18, 2017 | 04:18 PM
L5wolvesf's Avatar
Where have I heard these words before ?
Old Aug 18, 2017 | 05:09 PM
ksti's Avatar
Did you check that new battery for voltage?
Old Aug 18, 2017 | 05:13 PM
ksti's Avatar
Did you check the voltage on that new battery?
Old Aug 18, 2017 | 09:24 PM
86-turbo's Avatar
Just a heads up that it's common to have a bad fuse box in the driver's kick panel. water leaks are common to short it out. Look for brown water stain above the fuse box. The cowl drain rusts out and leaks into the kick panel area often.
Troy68
3.4 Swaps
24
Aug 14, 2017 06:14 PM
Melrose 4r
Jul 10, 2017 07:30 AM
Pri$erulz
Jul 6, 2017 04:01 PM
calderp
Jun 3, 2017 07:41 PM
Tilikum102602
93-98 T100s (Build-Up Section)
May 24, 2017 10:01 AM
