NO cut ZUK spring options
Old May 25, 2011 | 09:29 AM
VonMussa's Avatar
I know 96-98 4runner rear springs are supposed to work.
Someone has mentioned Jeep springs will also do the trick. Does anyone know which years?
Any other options?
Old May 25, 2011 | 11:22 AM
blake.nemitz's Avatar
i did it on my buddys runner with 95 rear runner coils, fit over bumps without cutting, however it was a bear to get them on even with removing shocks and shackle, good luck
Old May 25, 2011 | 02:50 PM
Outsane's Avatar
I used lowering springs from for an Acura TL, I didn't cut the springs or the body
Old May 25, 2011 | 03:02 PM
dlucky894runner's Avatar
I have been looking at wanting to do the same thing. I have heard these might work. I have measured them and the inside diameter of the 125lb rate springs will fit over the bumpstops. I will be ordering them shortly and trying them.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old May 25, 2011 | 05:20 PM
VonMussa's Avatar
Let me know if they fit.
Old May 26, 2011 | 08:08 AM
Will do. I just ordered them. The listing is only for one spring, so it actual costs around $80 for the pair.
Old May 26, 2011 | 09:50 AM
ZUK's Avatar
ZUK
Hey dlucky-- Those coils are 13" long.....I see they also have them in 16" here
http://cgi.ebay.com/ebaymotors/NEW-R...Q5fCarQ5fParts
with those larger 5" OD coils you don't have to cut the upper steel stopper....so you can just slip them over the outside similar to the TJ coil. The lower portion of those coils looks to be a bit of a loose fit over the rubber snubber..... a pigtail would be nice but I don't see an option in the 13" or 16" length. Keep us informed how the 5" OD coil fits on the topside.
Old May 26, 2011 | 09:59 AM
Will post some pix, before, during, and after. I didn't want to have to cut the bump stops off. I talked to the seller and he stated the ID is different depending on the rate of the springs. I only asked about the 125# spring. The ID on those is approximately 4.125". I should get them about Wednesday next week. I will let you know what happens.
VonMussa, sorry for thread jacking.
Old May 26, 2011 | 10:57 AM
ZUK's Avatar
ZUK
I'm betting that your pics will be very interesting to VonMussa....VonMussa's question-front TJ coils of all years should work aok...1998~2011. Fortunately, the fronts are plenty long enough so they can be cut down if needed. I seem to remember them being about 17" long stock.
EDIT---Seems like 17" is probably alot longer than what they really are...probably closer to 14 or 15....just guessing at this point though.
Old May 26, 2011 | 01:07 PM
VonMussa's Avatar
Zuk, the TJ coils are 17"? Does that mean they will need to be cut down? I've got limited tools and limited mechanical know-how. I'm trying to keep this as cut free and minimal tools.
Old May 26, 2011 | 05:07 PM
ZUK's Avatar
ZUK
If you ended up with the TJ fronts then that might give 5" or a smidge more of lift. First though, let's see what the numbers are that you're dealing with.....these will tell me how long the coil should be and the minimum length coil so that it doesn't fall out during maximum articulation offroad.
1---on level ground what is the measurement for the space the coil will occupy?..... 8"?....9"?
2---Figure a way to SAFELY jack the rear bumper up such that the rear tires are just barely touching the ground and repeat the measurement. This should be done with the lower shocks hanging free so that they do not limit the drop of the axle.
Got a pic of your Runner in its present condition?
ps---I'm dumpster diving....probably later tonight. But I don't think you guys know what that really mean anyways
thanks ZUK
Old May 26, 2011 | 05:22 PM
VonMussa's Avatar
Hey Zuk, lemme know if you find anything useful. I'll pay top doller
My truck is stored right now, I'll try and get some measurements tomorrow or this weekend.
Old May 26, 2011 | 10:05 PM
ZUK's Avatar
ZUK
Dang....I pulled behind the building of a place that builds buggies and does lifts...no luck. The dumpster had a ton of cardboard in it but no coils. They might be separating the steel out for the junk yard value...not sure. Time will tell.
Old May 27, 2011 | 04:58 AM
Heck....That is an awesome idea. I wish I would have thought of doing that.
Old May 27, 2011 | 02:08 PM
VonMussa's Avatar
I need to find one of these places!
Old May 27, 2011 | 07:27 PM
twistedyota's Avatar
i used front coils out of a mid 80's jeep cherokee. no cutting at all.
Old May 28, 2011 | 03:30 AM
92 TOY's Avatar
this is likely what we will be going with. could someone let me know if this is right? this is getting kinda confusing.
Old May 28, 2011 | 12:09 PM
ZUK's Avatar
ZUK
There's another ZUK coil mod related thread here where the guy has just ordered those exact same coils.....wait and see how they work for him. ZUK
Old May 28, 2011 | 12:18 PM
92 TOY's Avatar
thanks man...I might be subscribed already. so much happening at home right now I can't keep up here and there and work.
Old May 31, 2011 | 10:42 AM
I'm the other guy, who just ordered those springs. They should be here on Wednesday/Thursday this week. I will post pics and such hopefully by Saturday.
