No Crank condition: 95 4runner 3.0
Old Mar 30, 2008 | 02:12 PM
YeeJ6's Avatar
so i just finished relpacing my buddies 3vze for him in his 95 4runner, attempted the first crank and all i heard was *click*. my first thought was the starter, but after listening and looking around i found that the starter doesnt even attempt to engage. the click is coming from starter relay:
and also this little guy here, which i think is related to the brake system:
Old Mar 30, 2008 | 09:17 PM
YeeJ6's Avatar
any suggestions?
Old Mar 30, 2008 | 09:24 PM
keithdphan's Avatar
if battery is good, check grounds
Old Mar 30, 2008 | 09:58 PM
Noltz's Avatar
I pulled the starter schematic for you.
Check the 80A ALT fuse in the junction block where you found the starter relay.
The relay then shunts power down through the Park/Neutral switch. Have you attempted to start in Neutral? It's a black wire w/white tracer, 12v+, going into the P/N switch, and it should be hot ONLY in crank. Assuming the switch is good, the black wire w/yellow should have 12v+ while cranking. This wire feeds the starter solenoid.
Hope that helps.
Old Mar 31, 2008 | 02:08 PM
YeeJ6's Avatar
thanks. ill use that diagram. any other suggestions?
Old Apr 2, 2008 | 05:17 AM
YeeJ6's Avatar
solved the problem, got the truck started last night. sounds pretty healthy. thanks for all the help to all those who posted!
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
redneck17
Jul 17, 2015 07:44 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
Roger Borba II
Jul 9, 2015 05:05 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
