No coolant flowin, need help please!
Old Dec 3, 2009 | 06:40 PM
redneckandy's Avatar
I have a 22re, runnin good now but i have no coolant flowin thru the hoses. started gettin hot so i checked it and theres none goin thru there. any ideas on why? and how to fix it?
Old Dec 3, 2009 | 06:56 PM
iamsuperbleeder's Avatar
did you properly "burp" the system?
if you're not sure, hit that 'lil "Search" button up there, and you know and to do
Old Dec 3, 2009 | 07:01 PM
myyota's Avatar
What hoses are you talking about, the heater hoses or the radiator hoses ?. The first place to start is checking the thermostat, either test the one you have to see if its opening or just replace it, also make sure there is no air in the cooling system.
Old Dec 5, 2009 | 03:51 PM
abecedarian's Avatar
The first place to check is the v-belt to the water pump is installed and that it and the water pump pulley are turning with the engine.
Then check if the heater blows hot air - the heater bypasses the t-stat so it should get hot even if the t-stat has failed. If it doesn't get hot, the water pump may not be operating or the passages / hoses / heater core may be plugged. If it does get hot, there's a pretty good chance the water pump is working and its time to check the t-stat and upper / lower radiator hoses as well as the radiator itself.
You can remove the t-stat and operate the engine without it just to verify that coolant is circulating through the radiator. As for the hoses, verify that the inner linings have not separated from the outer casings; if that happens, particularly on the lower hose, the lining can block coolant flow through the hose.
ladybugRC
458
Aug 21, 2020 10:41 AM
LittleUgly
15
Jan 2, 2020 01:30 PM
wberry85
May 17, 2016 05:45 PM
alexcarey
Oct 14, 2015 06:05 PM
kcaudill
Oct 10, 2015 02:39 PM
