No "constant" power to certain items
Old Dec 28, 2017 | 09:09 AM
RODKNOCK's Avatar
This is about a 2017 tundra 5.7l 4x4 crew max and a bad start. The vehicle was "jumped" backwards and blew the main fuse. That has been replaced and the truck starts and drives now, the windows work, backglass goes down,temp works ,speedo works,headlights ,taillights , ect. What is "not" working are the horn,any interior dome lights, lighter,radio,alarm {with remote} , and power locks{the power lock will not work by the switch unless the key is turned on ,and will stop working after a few min's of the key being removed. Obviously these items all should have a constant battery source. All individual fuses under hood and inside cab have been checked and are good.
Old Dec 28, 2017 | 07:42 PM
RAD4Runner's Avatar
Sounds like something you should take up with the Toyota Dealer, not in a 1995 and earlier 4Runner forum
Old Dec 29, 2017 | 08:16 AM
RODKNOCK's Avatar
Problem solved
Someone had removed the "short pin" from the relay box , thus not giving power 2 the 4 fuses. Dealers usually remove them for shipping purposes to save battery life. "on the road again!"
Old Dec 29, 2017 | 08:21 AM
RAD4Runner's Avatar
glad you figured that out
Dixyboy69
May 18, 2024 06:14 AM
ITO
Sep 13, 2017 07:48 AM
pwscottiv
Apr 20, 2007 09:45 AM
CoedNaked
Nov 18, 2004 11:39 PM
