No brakes after caliper/MC/booster swap.
Old Aug 22, 2013 | 06:15 PM
Yamiryder's Avatar
Originally Posted by scope103
When you "pump up" your pedal, is the pedal then relatively firm? (not spongy) Once you pump it up, if you hold your foot on the pedal, does it slowly sink to the floor? If so, it's almost certainly a bad master cylinder. Air in the lines should feel "spongy" (though how bad it is depends on how much air you have).
Yeah, I can get the pedal firm then hold it and it goes to the floor. Which is why I really think its he master.
Old Aug 23, 2013 | 04:31 AM
RustBucket's Avatar
Definitely sounds like the MC if it won't hold pressure as you're describing.
Old Aug 23, 2013 | 04:40 AM
Yamiryder's Avatar
I drove the truck to work today, gonna stop at a local mechanic that knows Toyotas on the way home. When you hit the pedal the first time, goes to the floor with very little stopping power. Pump it once or twice and it has decent pressure and it holds it enough to stop. I'm still trying to figure it out haha.
Old Aug 23, 2013 | 06:54 AM
RustBucket's Avatar
Right. What you just described sounds like a bubble in the system. If you build pressure and it won't sustain it, then it's the MC (or a leak).
Old Aug 23, 2013 | 07:53 AM
  #25
Yamiryder's Avatar
Could be a bubble but I have no idea what else to do to bleed the system more.
Old Aug 23, 2013 | 01:24 PM
  #26
oldblue's Avatar
make sure you didn't put the calipers on the wrong side. the bleeder port needs to be on the top side of the caliper. if not you'll never bleed it out.
Old Aug 23, 2013 | 07:31 PM
  #27
Yamiryder's Avatar
My drums were out of adjustment. How they got that way I don't know because I didn't take them off but I adjusted them and my brakes are back!
Old Aug 23, 2013 | 10:27 PM
  #28
wyoming9's Avatar
Red face
Your Emergency brake keeps the rear brakes adjusted up.
They do have to be adjusted up to begin.
It does work?
You do use it??
Old Aug 24, 2013 | 05:34 AM
  #29
Yamiryder's Avatar
It does work?
You do use it??
Nope e brake doesn't work.
Old Aug 24, 2013 | 05:48 AM
  #30
wyoming9's Avatar
Red face
well when you get to much pedal travel again time to adjust the rear brakes again.
Myself I can`t stand not having a emergency brake not working
I have fixing them down to a science .
Old Aug 24, 2013 | 05:58 AM
  #31
Yamiryder's Avatar
I need the pivoting part that bolts from the inside of the drum. Mine rusted off.
Old Aug 24, 2013 | 06:10 AM
  #32
bhawkin00's Avatar
Look at a transfer case brake. They run about $230 an it will work with the factory ebrake handle.
Old Aug 24, 2013 | 07:36 AM
  #33
Yamiryder's Avatar
That's more than I want to spend on an ebrake. And I can get mine working I just havent
Old Aug 24, 2013 | 07:50 AM
  #34
wyoming9's Avatar
Red face
Most likely you will need the bell cranks and the bell crank brackets .
I have never had bell cranks rust off just seize in the brackets .
It should be easy to get the bell cranks from some one down south.
Old Aug 26, 2013 | 04:47 AM
  #35
Yamiryder's Avatar
I can get a bell crank kit off the internet for like $40 so that's what I'm doing. I have 2 new ebrake cables lying around too so I should be good in a little here
Flying91
45
Apr 11, 2024 04:39 PM
1992pickupSr5
May 9, 2019 08:44 AM
stoneboy91
Apr 5, 2016 05:17 PM
bfmcelroy
Aug 18, 2015 06:42 AM
CanRunner
Jul 20, 2015 01:29 PM
