new tires, quick question
Old Feb 21, 2007 | 01:11 PM
itsmeagain5789's Avatar
this is gonna sound stupid, but what is the recommend street tires pressure for the 32x11.50 bfg m/t? also, how much will this affect my speedo.(tried lookin for the calculator but i couldnt find it) thankks guys
edit
nevermind on the calculator, just found it here http://www.4crawler.com/4x4/4LoCalc....peedoConverter
Old Feb 21, 2007 | 01:21 PM
MudHippy's Avatar
Recommended MAX press. on the ones I have here says 50 p.s.i., however the pressure Toyota recommends is located on the metal plate next to the drivers' side door latch. There's a site with a calc. somewhere, hold-on....
Old Feb 21, 2007 | 01:22 PM
Elton's Avatar
32-35psi
Old Feb 21, 2007 | 01:24 PM
oh ok, i thought since there different tires they might need to go up to like 40psi. but i guess not. i got 30psi in there right now.
Old Feb 21, 2007 | 01:30 PM
91TPU's Avatar
i keep my 31inchers at between 30-35psi
Old Feb 21, 2007 | 05:39 PM
ovrrdrive's Avatar
I've always run my 32's at 35psi... They still ride a little in the middle of the tire but not bad. Any less hurts gas mileage and any more they wear out the middle first...
Old Feb 21, 2007 | 05:54 PM
CJM's Avatar
CJM
The plate/sticker on the door jamb and what manual says are for STOCK TIRES!!! Really how many times do I need to say this!!!! STOCK TIRES ONLY!!!!
Here is what you do, take the max pressure and fill to about 5-8psi less, take a piece of chalk and draw a line across the tires and drive in a straight line for a bit. Get out and check for even wear of the chalk line, if its worn off 100% tire inflation is right, insides worn inflated to much and outsides worn inflated to little. Then remember that number!
jasonty
41
Dec 23, 2018 01:00 PM
coffey50
Jul 28, 2015 10:55 AM
DrZero
18
Jul 24, 2015 11:31 PM
icentropy
Jul 14, 2015 10:23 AM
