New pro-comp shocks installed and clearance issue
Old 12-15-2007, 03:40 PM
SKNKWRX's Avatar
Put innew procomp es 9000s today and in the front the shock body touches the bumpstop on the UCA. This cant be good or right. anyone else had this issue?
Old 12-15-2007, 03:42 PM
fillsrunner4's Avatar
i had the same ones a long time ago no problems. thats weird. do you have a lift on it?
Old 12-15-2007, 03:44 PM
SKNKWRX's Avatar
t bars cranked a bit thats all. BJ spacers go on tomorrow
Old 12-15-2007, 03:49 PM
i bet it happend with the tbar crank. I would chop the bracket off and fab up a new one for it if you can i dont think you could do much to fix it unless you did that
Old 12-15-2007, 03:57 PM
SKNKWRX's Avatar
well tomorrow some grinding wil def happen
Old 12-15-2007, 03:58 PM
Hell yeah good luck and keep us informed
Old 12-15-2007, 05:36 PM
FredTJ's Avatar
Mount 'em the other way around if they can be. Check the specs to make sure.
Fred
Old 12-15-2007, 05:51 PM
SKNKWRX's Avatar
Fred
they said this end down so I mounted them that way
Old 12-16-2007, 05:47 AM
nmtoy's Avatar
Mine did that with the 9000's too. I just ground the bumpstop bracket a little bit and it was fine.
You can't flip the shock because the top mount is a threaded rod and not an eye like the bottom.
When you install your BJ spacers you will have the grinder out anyway.
Robb
Old 12-16-2007, 05:49 AM
nmtoy's Avatar
Oh, and lose the shock boots.
Old 12-16-2007, 06:22 AM
SKNKWRX's Avatar
i like my shock boots i know everyone hates them blah blah blah
bigjstang
08-25-2021 12:41 AM
raptor510
02-17-2017 07:11 AM
Yotadawgjr
10
08-23-2015 10:51 AM
Massmayhem247
07-18-2015 05:46 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: New pro-comp shocks installed and clearance issue
