new cv axles?
new cv axles?
hey everyone...im looking to replace my cv axles on both sides....any suggestions where would be the best place to purchase them? im gunna install my bj spacers soon so i wanna change the axles while im in there. thanks!!!
Buy a used axle from a wrecking yard, or buy a remanned one from a parts store. Whatever you do, DON'T get the new ones. They are cheap knockoffs made in China, and often times do not fit correctly or have problems or issues associated with install. To add on to that, they are made of inferior materials, and have a tendancy to break easier.
I bought the remanned (re manufactured) CV's from Autozone for $69 each that have a lifetime warranty on them. I actually screwed up installing one of them and tore the boot and took it back down and swapped it out no questions asked. A lot of people around here are running them and I haven't heard anyone complain yet about them.
i work at napa and you can get reman cv's, they do come with a core charge but they're prob cheaper than autozone... autozone sucks btw... they come with a limited lifetime warranty which means if the product breaks cuz of a defect then its covered, if it breaks cuz it was installed wrong, then the warrenty is cancelled... but if it breaks, just take it back and tell them it broke, nothing else, they'll most likely order you a new one if they dont have it in stock... they really dont care cuz they arent losing out on the money situation, they're just the middleman... i havent had anyone come back cuz of defective products like that, i was thinking about buyin two new reman ones cuz they only cost me 40 bucks a peice with my discount ha ha
If yours aren't broken why change them? Just get new boots (if you need them) and grease. My original 93 CVs are still doing good (knock on wood), I did put new boots (OEM) in 2002 and they come with new grease.
Its not like you have to take off the CVs to do ball joint spacers.
Well I do carry spares, just in case. And I pressed out the studs on flanges so they are easier to replace on the trail.
When I had my front end apart doing the lift I also changed out the old front diff to one I bought with 5.29's in it. While I had everything all apart and separated I went ahead and installed remanned CV's for piece of mind. I also had a torn boot on one of the old ones so it was just so much easier to change all of it out.
Now that I have the lifetime ones in I also don't have to worry about buying them again either.
