New clutch shifting into revers issue
Old Mar 9, 2023 | 05:52 AM
markf1's Avatar
Originally Posted by Chuck the mechanic
the reverse gear in those transmissions are so small in general comparison that they get mushroomed (cogs compressed) and the grinding is because the drive gear isn’t fully meshing reverse gear. Only way to repair is replace with a new reverse gear
Thanks for you reply. I took the truck back to the mechanic and he made it better. I think he adjusted the travel of the clutch pedal, but it’s been almost two years ago so memory is a bit clouded.
Old Mar 9, 2023 | 07:14 AM
JJ'89's Avatar
Originally Posted by 87-4runner
Put it in 1st gently nudge it forward, just barely, then go to reverse... works every time.
That's right. Exactly.There's no "syncromesh" for reverse. If two gear teeth are trying to occupy the same location you have to move one of them. Do it the easy way, so they can mesh.... https://en.wikipedia.org/wiki/Gear
Old Mar 9, 2023 | 07:33 AM
markf1's Avatar
I will do that and thanks!
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
dsbk1
Feb 29, 2012 07:42 AM
cruiserjim
May 27, 2011 05:49 AM
ilikefjords
Jan 25, 2010 03:41 PM
buckshot1224
Dec 3, 2009 07:40 AM
