Need Repair Cruise Control 1986 Toyota SR5 4WD
Old Oct 3, 2016 | 11:49 AM
ewong's Avatar
Try to find a FSM (factory Service Manual) - If I recall, there is an extensive trouble shooting guide in that
Old Oct 3, 2016 | 12:14 PM
atcfixer's Avatar
5 Year Member
I checked the truck I'm parting out and the passenger side one isn't bad, but has the typical retract problem. The driver's side the bolt is rusted too badly and the head is about gone. Could grind it off, but plate metal if fairly rusty though and suffers from the same retracting problem as the other side (if pulls fine if you feed it). I've read about people taking them apart and twisting the spring a couple extra times for the stronger pull, and remove the strap and wash it in your washing machine to reduce friction. Same thread mentioned about silicone spray as a lube on the strap.
I'd have to go over the center latches and strap to see what shape it was in, but it came out well for rust wise/bolt quality. This is from an xtra cab, not sure if there is any difference from reg cab ones or not.
Old Oct 6, 2016 | 09:45 AM
Samson3113's Avatar
Thanks ewong
I have a FSM. I will see what I can find in it. I am not to good with checking voltages and electrical issues
Jim
Old Oct 6, 2016 | 09:46 AM
Samson3113's Avatar
Thanks for checking atcfixer
Jim
Old Oct 14, 2016 | 01:26 PM
  #25
mbomberz1's Avatar
I need a drivers door SR5 armrest in gray!!!
Old Oct 17, 2016 | 04:51 AM
  #26
arlindsay1992's Avatar
The FSM has a section on troubleshooting the cruise control system. There's actually a self diagnostics feature similar to the engine on board diagnostics. It blinks the cruise control light in a certain series based on the problem. Aside from checking the basics like broken wires, cracked/broken vacuum line, or cruise control cable in need of lube, this is your best place to start.
Old Oct 27, 2016 | 09:37 AM
  #27
Samson3113's Avatar
Thanks arlindsay1992
computer down for a while
could not get back to you
Jim
RatLabGuy
Sep 18, 2023 04:07 PM
irv
Jun 30, 2017 10:31 AM
vasinvictor
Sep 18, 2016 01:40 PM
Topteke
10
Sep 13, 2016 09:04 AM
cbr600rx7
Aug 31, 2016 06:13 PM
