Need Pin Outs - Front Power Window/Lock Cross Reference
Old Apr 16, 2018 | 06:55 AM
stanz's Avatar
My front door power window/lock control module on my 86 4Runner is on it's way out. Finding a replacement module is next to impossible. I found an 89-90 module on ebay for cheap and noticed that the wire harness plug is the same.
I know better than to assume that all of the pins are arranged the same. I am hoping someone has the pin out & schematics for both the 84-88 window control module box as well as the 89-90 module box so that I can compare and move pins, if necessary.
Thanks in advance!
Old Apr 16, 2018 | 10:56 AM
wyoming9's Avatar
Red face
Do you know where the Relay is located ?
I have no idea if it works but could test it it is out of the 86 pick up.
Old Apr 16, 2018 | 11:00 AM
stanz's Avatar
It’s located above the steering column under the dash. It has a slot that allows it to slide and lock onto a bracket.
it looks like this:
Old Apr 16, 2018 | 05:23 PM
RAD4Runner's Avatar
IIRC, I got this from PDF version of 1988 FSM. (Ignore troubleshooting notes).
I like your TNW logo
Seen The West Coast one?
Old Apr 17, 2018 | 12:43 AM
wyoming9's Avatar
Red face
As soon as The monsoons quit I will check things out
Old Apr 17, 2018 | 10:38 AM
Hiddenforest's Avatar
You can still find them at the dealers at a gold mine price of 250 bucks. I burned mine out after replacing the door panel switches. The wires were run wrong & since i've been search junk yards but SR5 4runners can be well picked over or they are burned out already. Happened to me twice - found the control unit and it locked the doors and the other one worked with the power windows but none of them did both. Thinking about selling my 4runner to but the control unit.... (kidding)
localfiremedic
Mar 17, 2016 05:11 PM
NorthIdahoyota
Sep 8, 2012 06:08 PM
anthony1
3.4 Swaps
Dec 4, 2011 01:14 PM
milehigheric
Oct 11, 2009 09:23 PM
GTBGUY
Jan 14, 2003 03:15 AM
