Need Pin Outs - Front Power Window/Lock Cross Reference
My front door power window/lock control module on my 86 4Runner is on it's way out. Finding a replacement module is next to impossible. I found an 89-90 module on ebay for cheap and noticed that the wire harness plug is the same.
I know better than to assume that all of the pins are arranged the same. I am hoping someone has the pin out & schematics for both the 84-88 window control module box as well as the 89-90 module box so that I can compare and move pins, if necessary. Thanks in advance! |
Do you know where the Relay is located ?
I have no idea if it works but could test it it is out of the 86 pick up. |
It’s located above the steering column under the dash. It has a slot that allows it to slide and lock onto a bracket. it looks like this: https://cimg3.ibsrv.net/gimg/www.yot...e0b25b656.jpeg |
IIRC, I got this from PDF version of 1988 FSM. (Ignore troubleshooting notes).
https://lh3.googleusercontent.com/8f...=w1155-h743-no I like your TNW logo :) Seen The West Coast one? |
As soon as The monsoons quit I will check things out
You can still find them at the dealers at a gold mine price of 250 bucks. I burned mine out after replacing the door panel switches. The wires were run wrong & since i've been search junk yards but SR5 4runners can be well picked over or they are burned out already. Happened to me twice - found the control unit and it locked the doors and the other one worked with the power windows but none of them did both. Thinking about selling my 4runner to but the control unit.... (kidding)
