Need lift and tire opinions
Old Mar 5, 2007 | 08:14 AM
ToyYoda's Avatar
I've got an OEM solid front axle on my toyota truck with a 4 inch. lift currently. Since the lift kit is worn out and old, I was thinking about going with a 7" SkyJacker lift and putting on some 36/12.5-15 TSL/SX tires on a 15x8" rim with 4 inches of backspacing. Does anyone know if this will work or not and what can I expect? It's already geared for bigger tires.
Old Mar 5, 2007 | 10:01 AM
Yota Tony's Avatar
Skyjacker sucks!
Look at Sky Manufactoring or Marlins.
Or go the cheap route and put stock rear springs in the front and 63" Chevy's out back.
You do not need 7" of lift for 36s.
Old Mar 5, 2007 | 11:28 AM
ToyYoda's Avatar
I've got 4 inches of lift right now but it seems a bit too low to fit 36" tires. Why does SkyJacker suck? I've gotten steering stabilizers from them that looked to be awesome and tough quality.
Old Mar 5, 2007 | 11:48 AM
design311's Avatar
Skyjacker springs aren't as flexible as some of the other options out there:
Trail Gear: http://trail-gear.com
All Pro: http://allprooffroad.com
Marlin: http://marlincrawler.com
...or go with what I'm doing, rear springs up front and chevies in the rear
Most guys are clearing the 36" Iroks with the 4" springs and some use the 5", but not much more lift than that. Gets a little too tippy. Might also make sure your wheels have enough backspacing to push the tires out farther for stability.
Old Mar 5, 2007 | 01:46 PM
91ToyTrck's Avatar
Alcan, Marlin, Allpro, or Trail-gear ... wouldn't go cheap when it comes to leafs.
Old Mar 5, 2007 | 02:58 PM
ToyYoda's Avatar
That's the truth. The kit on the truck now is crap. The leaf spring bushings are dry rotted and pushing out....along with the shock bushings It is an older kit but they didn't use poly bushings and the springs are way too stiff.
I'd like something around a 4 or 5 inch. lift. Where I go wheeling, there are a lot of rocks to climb but also mud pits so I'd like something that has awesome flex but will also be good in the mud.
I am going with 33/12.50-15 on a 15x8 rim with 4 inches of backspacing. Does that sound good?
Old Mar 5, 2007 | 06:29 PM
design311's Avatar
Well, that is kinda cutting it close. Ideally it should be around 3.75" or less. I personally am going to run some custom MRT's with 2.5" backspace. Plenty of width to compensate for the added height. 4" BS or more and you chance interference with the tie-rod ends.
Old Mar 5, 2007 | 07:03 PM
91ToyTrck's Avatar
You should be able to fit 35x12.50s under your sas'd rig with 4-5" of lift. I would think a 3.5" bs'ing would work better,but there is a guy running stock rims, 35s, and sfa on here. I know that combo works and works good from his vids and pics.
Old Mar 5, 2007 | 10:49 PM
ToyYoda's Avatar
I'm having a hard time finding rims that are less than 4 inches of backspacing; I thought that would be too much. There are some other brands but they cost too much considering they are only 15" rims. I have landcruiser rims (not sure what year) on my truck right now and the backspacing seems too deep and they are too close to everything in the front and the back, especially if I want to put a taller and wider tire on those rims. Where can I find a good deal on some not too expensive rims?
Old Mar 6, 2007 | 05:20 AM
design311's Avatar
http://store.summitracing.com/
1-800-230-3030
Old Mar 6, 2007 | 12:28 PM
91ToyTrck's Avatar
I was going to say the same thing to him. I'm sure you can find some on there that suit your needs. You can even search wheels in different ways ... even by backspacing. I say Summit firstt then maybe check some forums or ebay for listings of the same wheels at a good price.
Old Mar 6, 2007 | 01:51 PM
Yota Tony's Avatar
Skyjacker rides like poop and the quality ain't great.
My lift when finished will be about 5" and I'll only have 33s for this, it's gonna be goofy
Don't forget the sawzall is your best friend.
Old Mar 6, 2007 | 01:58 PM
4banginRunner's Avatar
my dad ran 37s for a few days with 4" ProComp kit on his 93 pickup they rubbed but not as bad as u would think and i can run 35s on my stock 79 pickup, my cuz ran 38s on his 80 pickup with a 3" lift
Old Mar 6, 2007 | 03:31 PM
Yota Tony's Avatar
I can put 33s on my 82 as it sits right now.
Well...the front might need some trimming.
Old Mar 6, 2007 | 05:27 PM
ToyYoda's Avatar
I'm thinking about going with 33 inchers since it's my daily driver. That also means that the lift kit I choose probably shouldn't be too loose on the road. My 86' 4runner had excellent flex in the back, did well in the mud, the rocks and on the road. Decisions decisions, I just can't make up my mind.
Old Mar 6, 2007 | 06:14 PM
Yota Tony's Avatar
Marlin.
Best semi bolt on kit you can buy.
Old Mar 6, 2007 | 06:39 PM
ToyYoda's Avatar
These are the rims I think I'm going to go with. http://store.summitracing.com/partde...5&autoview=sku
Do all those lift kits require the 86-95 power steering gear box?
Old Mar 6, 2007 | 06:53 PM
Yota Tony's Avatar
Yes.
Most lift kits will.
You need an IFS box for high steer and high steer is so worth it.
Old Mar 6, 2007 | 07:01 PM
mauibuilt's Avatar
sup boyz i got a question might be off your topic.i have a 2002 tacoma 4x4 TRD 6 lug right and i need to know if MT rims off a 1978 6 lug chevy blazer will fit.or email at trdhawaiian@yahoo.com
Old Mar 6, 2007 | 07:57 PM
91ToyTrck's Avatar
If those are the rims for you then by all means run with them. Those are a nice clean wheel and should add a touch of "bling" to your trucks appearance.
