Need help. Speedo
Old Jan 18, 2015 | 07:46 PM
Shagool22's Avatar
Need help. Speedo
I'm in the middle of a transmission swap in my 1987 4Runner (Auto to 5speed).. I picked up a w56 tranny and tcase from a buddy (knowing its history made it a good deal for me).. Anyways, the transmission is electronic speedo, my truck is mechanical speedo. Do not want to alter my cluster. Can I just replace the electronic sending unit for a mechanical one? Does anyone know where i can get one? Please point me in the right direction this is the only thing holding me back at the moment.
Old Jan 19, 2015 | 01:50 AM
Terrys87's Avatar
It has been a long time ago but seems like I tried to that with out much luck on it. I was new to Toyotas and might have missed do something to make it work. Looking forward to your results.
Since it is an electronic driven speedo, it came out of a 92 or newer truck.
Old Jan 19, 2015 | 05:07 AM
vasinvictor's Avatar
Here is what you seek. https://www.yotatech.com/forums/f116...ersion-213468/
Old Jan 19, 2015 | 11:32 AM
Shagool22's Avatar
Terry will let you know how it works out! I'm pretty determined to find one that works.
Victor I did see that thread as well. So it does look like it's possible. Just was hoping someone would know where to find one. I need the larger mechanical one. Cause I'll have to pick through some junk yards in hopes they might swap me. Thank you guys
Old Jan 20, 2015 | 08:12 AM
Shagool22's Avatar
Found a mechanical speedo unit at my local wrecking yard. Same bore size as the electrical unit. Will let you know how it works out after work.
Old Jan 20, 2015 | 06:46 PM
Shagool22's Avatar
Was a perfect fit!! Anyone wondering the same question it is possible to swap out of you can find the right bore size sending unit. I believe there's 2 sizes. Do not know measurements, big bore and small bore (easily distinguishable)
Old Jan 20, 2015 | 06:48 PM
Shagool22's Avatar
was able to find one at a wrecking yard. Perfect fit!!
zytra
Jan 24, 2019 03:16 PM
Shagool22
Sep 28, 2015 07:53 PM
fountain
Sep 28, 2015 03:04 AM
charlie_fong
Sep 27, 2015 10:06 PM
LotOMiles
Sep 14, 2015 11:45 PM
