Need help sanding
Old Sep 26, 2009 | 08:41 PM
ColoradoRyan's Avatar
Need help sanding
I'm getting close to painting, but I have kind of a mess with sanding. What should I do about this? The clear coat was flaking off in a lot of places, some places the top coat was worn. So I started stripping with 80 on a drill and this is what I have because I couldn't decide what layer to go to. Starting at bare metal there is a gray, then red, then gray, then silver metallic, then clear coat, (or at least there was). I originally wanted to go down to the red but I kept burning through it to metal.
I want to spray with urethane bc/cc solid white. How uniform does this have to be before I shoot primer? Right now I've got a bunch of different levels from bondo to metal to all stages of oem paint. I'd rather not strip to bare metal if I can avoid it. The few areas i've burned through I've sprayed with rattle can etch primer.
Thanks for any help...
Old Sep 26, 2009 | 08:49 PM
YodaMonster's Avatar
depending how straight you want your rig... sounds like sanding with a drill isnt a good idea. can you feel the different levels of paint when you run your hand accross? if so i would take it down to metal, if you dont want it looking like the ocean after its painted
Old Sep 26, 2009 | 09:21 PM
RobD's Avatar
http://www.hotrod.com/techarticles/b...ock/index.html
Old Sep 26, 2009 | 11:03 PM
peow130's Avatar
if you have a decent size air compressor, go pickup a Dual-action sander.
it's orbital or circular..
Old Sep 27, 2009 | 01:15 PM
Yeah the drill isn't the best idea, corded was horrible but the dewalt cordless are doing ok because they are variable speed so I can go slow, but probably should not have been using 80 grit unless I wanted to go down to bare metal. I can't feel the difference in the paint levels so I'm just going to spray bomb the burn throughs with rattle can etch primer, then block with 220, prime and see how bad it is.
Here's a pic of where I'm at:
Originally Posted by 02/89yota
I did the same thing on a drill and ed it up. Go buy a sanding block, and then ALOT of sand paper. It's going to take time, but will be worth it. My truck is getting repainted, I am redoing ALL the ty Bodywork I did. I did the same thing, did a Lexus Diamond Pearl White. You can't tell its pearl because of the ty body work. TAKE YOUR TIME.
I can show you pics if you would like
Yeah I guess you and me like to learn the hard way lol. Sure pics are always awesome.
My air compressor is a bit small for that and I'm all out of cash. I agree those sanders are the proper way to do it though.
Thanks for the link, very useful.
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
MudDr
Sep 12, 2015 01:47 AM
JookUpVandetti
Sep 11, 2015 09:41 AM
Dakotaneu
Aug 15, 2015 07:24 AM
