need help on rebuilding 22re
Old Dec 12, 2012 | 09:54 PM
rockfiend's Avatar
seeing if ne one can help me identifying a problem.
i just got the head off n was checkin things out wen i notice that piston 1 moves before piston 4 does at tdc. was seeing if ne one ever had this problem. wen the rod goes side to side piston 1 moves slightly up n down but piston 4 doesnt. is the rod too long? or the crank bad or bearing out of round? i never seen this before, if ne one can help me narrow down this problem i'd appreciate it...
also this is my first rebuild
Old Dec 13, 2012 | 06:57 AM
Hurakane's Avatar
Your gonna try and rebuild that 22re? you checked the the crankshaft? or maybe the piston rod itself might be bent,broke etc?
Old Dec 13, 2012 | 09:01 AM
rockfiend's Avatar
i have 2 long blocks but the other one is seized up and the block has been resurface too far that it needs a shim. i havent measured the crank or rods.(dont have the tools). but ill try that first.
bigjstang
Jun 2, 2025 03:56 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
coleypull15
Nov 3, 2015 07:41 AM
shisha1999
Sep 21, 2015 08:22 PM
shadowbirdie
Jul 21, 2015 10:38 PM
