Need help identifying this piece!!
Old Feb 12, 2020 | 09:35 AM
Lawrence Bullock's Avatar
Was changing my oil pump and found this under the car.. could it be for the PS pump belt tensioner??
Old Feb 12, 2020 | 11:19 AM
2ToyGuy's Avatar
PS pump idler, or the AC idler pulley. One of the two.
It's what the bolt goes through that holds the pulley, and allows it to slide back and forth in the tensioner. IIRC, it goes throught he slot, with the wide part on the forward part of the slide slot, IE on the outside, and the small part sticks into the slide slot. Then the pulley's bolt goes through it, with the pulley bearing essentially resting against your little part. Then once you have it tensioned, you tighten up the unt on the bolt to hold it in place. Be careful, tightening the bolt up can change the tension, so you should check the tension, and reset it if needed.
Good luck!
Pat☺
Old Feb 12, 2020 | 07:45 PM
Good luck!
Pat☺
Got it all back together. Thanks bro I greatly appreciate it
buckz6319
Dec 14, 2024 05:03 PM
87hillbillyoter
Sep 15, 2010 09:40 PM
icebear
May 26, 2010 06:36 PM
Saiba Samurai
Oct 7, 2009 08:33 AM
