Need help identifying a part and how it is to be plumbed
Old Oct 8, 2013 | 10:47 AM
c310pilot's Avatar
Greetings. First time poster and first time engine rebuild. I have found a lot of great info here so thanks to all who have contributed.
I have a 92' 22re pickup that I have had for almost 20 years. Since it leaked from everywhere, I decided to go ahead and replace a bunch of stuff:
plugs, wires, distributor cap, rotor, all seals, head, clutch, fly wheel, battery, oil pump, water pump, timing chain and gears. Basically a complete tear down except pistons, rods, and crank.
In my haste, I broke a couple of sensors which I am replacing, knock & cold start injector thermal switch. The engine runs but surges really bad. While I am waiting for a replacement cold start sensor there are a couple of items in which I didn't document well enough to re connect properly. Some help would be greatly appreciated identifying the parts and proper plumbing.
For the life of me I cant find this in the manual. It's located right next to the cold start injector. I have two hoses on the bottom that aren't connected to anything. Whats it do?
On my fuel pressure regulator, the vacuum hoses, where do they connect. I assume the only place I am missing one which is on the hard vac lines by the EGR stuff but I hate guessing. The diagram I have found is kind of tough to read.
After doing all this work, I definitely appreciate the old Toyota much more now!
Thanks!
Attached Thumbnails Need help identifying a part and how it is to be plumbed-003_zpse26b36e1.jpg
Old Oct 8, 2013 | 12:43 PM
Kiroshu's Avatar
Picture shown above in your original posting is the "Fast Idle Speed Adjustment Valve" for Air Conditioning and Power Steering equipped trucks.
Old Oct 9, 2013 | 11:44 AM
c310pilot's Avatar
Thank you. I am confused on the Fast Idle Speed Adjustment as I have before and after pictures and I don't think it was ever really plumed into anything.
Attached Thumbnails Need help identifying a part and how it is to be plumbed-iac2.jpg   Need help identifying a part and how it is to be plumbed-iac1.jpg
88sasturbotoy
Jan 30, 2026 01:57 PM
mskalmus
May 28, 2017 07:51 AM
May 20, 2016 10:27 AM
rushw
Jul 18, 2015 01:46 PM
Fundy Rider
Jul 16, 2015 01:35 AM
