Need help find tdc on 22re
Old Feb 26, 2015 | 11:13 AM
Scotto6591's Avatar
So I took apart my motor to do the timing chain and head gasket, had the motor at TDC on the compression stroke and pulled the head. Now I'm ready to put everything back together and it looks like someone moved the crank around. How can I get it back to the correct TDC position?
Old Feb 26, 2015 | 11:21 AM
millball's Avatar
If the head is off, just roll the crank around til #1 piston is up and the crank pulley mark is on 0'.
Old Feb 26, 2015 | 11:29 AM
scope103's Avatar
Don't forget that the crank turns twice for each turn of the cam. As millball says, setting the crank is easy; just bring the piston to the top. Is that TDC on compression or exhaust? It isn't either until you put the head on. If you line up the bright links to the timing marks on both sprockets, it will go on at TDC Compression. (Which matters for when you install the distributor.)
Old Feb 26, 2015 | 12:33 PM
Odin's Avatar
^ This
Old Feb 26, 2015 | 05:07 PM
Scotto6591's Avatar
One more question Im going to be using a different head and the guy I got it from didn't pull it off at TDC,does it matter? Can I put it on as is and adjust the cam to 12oclock and then attach the rocker assemble and tighten the head bolts or do I need to adjust the valves also?
Old Feb 26, 2015 | 05:10 PM
millball's Avatar
Any time the rocker assembly is removed, the valve lash adjustments should be checked and corrected if necessary.
It is wise to chase the head bolt threads in the block and clean with compressed air before assembly.
Old Feb 26, 2015 | 05:23 PM
scope103's Avatar
Originally Posted by Scotto6591
... the guy I got it from didn't pull it off at TDC,does it matter? ...
No. You've got to line up the cam sprocket as part of putting the chain on; it doesn't matter where it starts from (I can't remember if the 22re is "non-interference" (the 3VZE is), so I would get the cam sprocket "close" before I put the head on.)
... or do I need to adjust the valves also?
I'm with millball; the easiest way to adjust valves is with the head off, so why would you skip the opportunity?
Old Feb 26, 2015 | 05:29 PM
millball's Avatar
scope- On a 22re, the rocker assembly is attached to the head by the headbolts which pass thru it.
The head and rocker arm unit must be attached to the block and the head torqued before valve lash can be set.
Old Feb 26, 2015 | 08:15 PM
scope103's Avatar
Thanks!
Old Feb 27, 2015 | 02:30 AM
Scotto6591's Avatar
I know how to reassemble the motor but the question I had was since the head I'm using wasn't taken off at TDC does that matter? Can I just set the cam to 12 o'clock then tighten the head bolts/rocker assembly down and adjust valves as needed?
Old Feb 27, 2015 | 06:25 AM
bswarm's Avatar
Just make sure the valves are not open on the cylinders that are at TDC so you don't bend the valves.
Old Mar 2, 2015 | 11:10 AM
Scotto6591's Avatar
Motor is all back together thanks
MO transplant
Apr 23, 2023 11:58 AM
steve miller
Oct 10, 2015 01:40 AM
thefishguy77
Jul 30, 2015 10:59 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
bryan34w
Jul 6, 2015 05:53 PM
