Need Help Diagnosing: 22RE Ignition or ECU failure, other? 86 4Runner Dead w/Code
Old Jul 17, 2022 | 09:50 AM
helikyler's Avatar
Originally Posted by 84sr5yoty
I had a bad internal wire connection to the plug where the for the distributor and ignitor connect that produced the same exact symptoms. Carefully wiggle all of the wires from one end to the other with the truck idling.
I'm working on this today... cleaning, dilectric greasing and reseating connections... We did find some poor connections under the hood.
Old Jul 17, 2022 | 08:27 PM
aztoyman's Avatar
I personally would not "rig" the wiring. It's one thing to do that on the trail to get home TEMPORARILY and another to do it permanently. JMHO.
I know how frustrating this is. I hope you get it figured out. On the positive side, this is how you learn every detail of how the system works. That's how guys that are good, got good.
Old Aug 14, 2023 | 12:29 PM
annamesa's Avatar
It sounds like you are discussing a wiring situation, possibly related to automobiles or electronics. I completely understand your point about not wanting to constantly rewire. It is important to ensure proper and safe operation, especially for long term solutions. By the way, earlier you asked me to find you something from online casionos, so I have information about https://casinosanalyzer.com/online-c...rtunecoins.com try to play there. You are right in that solving such problems can provide valuable learning opportunities. Hands-on experience and troubleshooting is a great way to gain a deeper understanding of systems and improve your skills. If you have specific questions or would like help with wiring or any other topic, don't hesitate to ask!
Old Aug 15, 2023 | 01:43 PM
scope103's Avatar
Yup, just what I'm looking for. A bot from a click-farm offering to answer questions on truck wiring.
Old Sep 4, 2023 | 05:36 PM
  #25
Bucket22's Avatar
I’m currently chasing this problem too. In my situation, it has thrown multiple different codes at different times when it stalls out ranging from Mass Air Flow sensor, to ignition problems and it starts sputtering and jerking, like you mentioned before, right before it turns off. Well I’ve changed the MAF sensor, the coolant temp sensor, distributor, and it just stalled again so the problem still persists. After checking the all the other stuff that the people above stated, everything checked out good. After further investigation, I found my passenger floor mat was soaked due to a universal AC unit I installed. It has been condensation and dripping on the floor which looks like it might have wicked up to the ECU. Just wanted to shed some light, as this will be my next fix. I will keep digging and update my finding. You’re not alone!
Old Sep 30, 2023 | 06:07 AM
  #26
Bucket22's Avatar
I changed my ECU and the problem was still there… that was a fail. I noticed that my engine was over fueling a bit and cased the truck to surge. I checked the pressure on my fuel rail and it was fine, but I didn’t stop there. I took out the fuel rail and inspected injectors and all the O rings were bad. Replaced the O rings and switched out the FPR while I was there and injectors. It ran like a charm after that! Hope this helps someone out there!
jmach1
21
Aug 16, 2021 02:55 PM
Chapin_X
Apr 29, 2020 06:25 PM
FirstGenRunner
Feb 24, 2012 02:26 PM
rvsmichael
Jan 5, 2009 04:46 PM
