need help with broken rear axle shaft
Broke a rear axle shaft right at the hub. I can't find any info on how to go about getting the rest of the shaft out while it is still locked in the diff.
Any suggestions?
Any suggestions?
The rear axleshafts aren't "locked in the diff". There's nothing holding them in except the wheel bearings, bearing retainers, and snap rings. Follow the procedure for removing the rear axleshaft and wheel bearing, the remainder of the axleshaft will slide right out still connected to it and the brake backing plate assembly. Piece o' cake!
http://personal.utulsa.edu/~nathan-b...33rearaxle.pdf
BTW, you can't "open the diff" without removing both axleshafts first either.
What would you people do without me?
To the OP - what were you doing when it snapped? The stock shafts are very stout and they take a lot of abuse.
it slid right out with ease once I could get a hold of it.
Thats the kicker. I have 37's but I was just cruising down the street doing about 50mph. Haven't even ever wheeled it with the 37's.
I suspect the extreme heat weakens the shaft and causes it to break in that spot.
Of course if it had snapped "right at the hub", that would've meant the wheel came of while he was driving 50 MPH. And he probably would have mentioned that fact.
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
FS[PacNorWest]: Rear chromoly axle shafts
A2theK
Jan 10, 2016 10:18 AM
jerusry
Oct 19, 2015 05:28 PM
toyoda8488
Jul 5, 2015 10:18 PM
