Need flexible fuel hose for 1994 Pickup
Old Oct 13, 2013 | 04:53 PM
alan8373's Avatar
Hi - i'm trying to replace the fuel line from the sending unit to the solid metal fuel line segment and can't find a replacement for the flexible line from the sending unit to the metal fuel tubing. I can't even find a part# online for it. Anyone know where I can find one? Even if I can just get a part# i can at least search for prices... no luck yet though.
Thanks in advance!
Alan
Old Oct 13, 2013 | 05:09 PM
bone collector's Avatar
what motor and transmission on your truck? 2wd or 4wd? it all matters.
Old Oct 13, 2013 | 05:12 PM
alan8373's Avatar
Oh - sorry - 3VZE V6, Automatic, 4x4.
Old Oct 13, 2013 | 05:15 PM
http://personal.utulsa.edu/~nathan-b...32fueltank.pdf
this should help
Old Oct 13, 2013 | 06:06 PM
alan8373's Avatar
Yeah i've seen that diagram - its in my hanes manual too. I dropped my truck off at the shop for inspection - they found a fuel leak in the metal line coming from the tank. I brought them replacement parts - the metal tube line, pump, sending unit, strainer, gaskets, and filter. They're saying there's one stretch of hose from the sending unit (which i think they mean pump - there's no fuel being sent from the sending unit), before it hits the metal fuel line. I'm not sure what this piece is - it's apparantly about 16" long. Any ideas? Does anyone have the parts diagram with part #'s for the fuel system from the tank forward?
I guess i could use generic flexible hose if necessary - i'm just not sure what size and what kind of fittings i'd need.
Thanks
Old Oct 13, 2013 | 06:12 PM
http://personal.utulsa.edu/~nathan-b...28fuelpump.pdf
if it is the piece of tubing that connects the fuel pump to the metal fuel sending bracket. just use high pressure fuel line. they usually send it in the box with new fuel pumps
Old Oct 13, 2013 | 06:41 PM
scope103's Avatar
This site http://www.toyotapartsoverstock.com/...rimLevel=18292 says it is a flexible line with crimped fittings, negating use of stock hose. You'll need to enter your VIN number; there are three part numbers given (23091-35030 plus two more) and your VIN number will separate it out.
bigjstang
Jun 2, 2025 03:56 PM
Regency
20
Jan 3, 2020 07:43 PM
Avenged
Jul 9, 2015 07:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
zd92655
Jul 5, 2015 04:25 PM
