Nasty Vibration
Old Apr 5, 2006 | 01:06 AM
wrenchmonster's Avatar
Rotating your tires will not make a difference because you are trying to determine if the varience between the front and rear is the problem. You're not changing anything in the equation. A+B=C or B+A=C ... it makes no difference.
Deflating the tires will also make no significant difference. This is not a rubber balloon we're talking about, it's a tire. Deflating/Inflating will only change the level of the vehicle and the contact pattern with the ground.
A 1/2 inch difference seems small but is deceptively large. You can't think of it like a piece of lumber. If you were to use the string method I decribed above you'd be surprised how much difference a 1/2 inch makes when you compare the two. The two pieces of string will not be different by 1/2 and inch, but maybe more like 1 1/2 inches. I'm no good at math at all, but maybe some of the math gurus will chime in.
Disconnecting the rear drive line will probably work, I just think the tire change is more conclusive since you will maintain load on both axles.
Beyond the string method, you could also get a piece of chalk and mark the tires 90 degrees to the ground. Then drive in a straight line for a while, get out and see where the chalk lines are front to rear.
Old Apr 5, 2006 | 04:15 AM
95SASMudRunner's Avatar
Originally Posted by Bobakazi
Is this something recent that started happening for no apparent reason and your Truetrac worked fine before, or was there some work done on it and you have the problem since?
It has been a problem since the start, i just have not known as i was dealing with separate issues; i have now resolved, ive got a buddy who im gonna borrow his tires and see how that plays out, i am hoping that this resolves the problem, though the only other issue i have not trouble shot it the front hubs, i suppose it is possible that one is not engaging fully but enought to not cause problems when not under load.
The Detroit guy said anything over 1% can cause problems and by doing the math a 1/2 inch is just over 1% thus if im pushing the 3/4-1" im over. Wouldnt have thought this was true but go figure.
hiluxinargentina
Sep 30, 2015 05:51 PM
JPV
Sep 28, 2015 03:15 PM
Odin
Sep 26, 2015 06:56 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
jjrbus
Jul 19, 2015 02:06 PM
