Narrow wheels, wide tires
Old Oct 24, 2018 | 07:34 PM
95YotaPickup's Avatar
I'm thinking about running stock alloy 7 inch wide wheels with 12.5 inch wide tires. Whats the verdict on that? Heard folks say it's great and you can air down and not worry about popping beads, and others say it's horrible on the street, wanders alot and wears down tires real fast. I need some opinions before I drop the coin on new tires. Thanks
Old Oct 25, 2018 | 12:42 AM
ev13wt's Avatar
5 Year Member
First off, why 12.5? For the look? For Sand? Style wise, I personally hate wide tires like that. Also fuel consumption. With the original rim offsett at least you don't screw with the angles for steering, so that is a plus.
Else, I'd stick with 10.5, 11,5. I am actually going to 33x9.5 or 31x9.5 to have more pressure on the road for wet conditions.
Quick Reply
The German TÜV, which checks all cars every 2 years + smog, reccomends https://www.motor-talk.de/forum/akti...hmentId=704923
7,0 inch rim
min 195 mm
optimal 205 oder 215 mm
max 225 mm
a 12.5 is 317mm wide. I cannot recommend it.
Old Oct 25, 2018 | 06:51 AM
az4x4runner's Avatar
That is pretty wide for stock rims, maybe someone here who has done it will chime in, but I can't imagine it handling very well. I have seen 11.50s on stock.
I'm looking for someone who makes 31x9.50 for my stock alloys for the reasons mentioned by ev13wt.
Old Oct 25, 2018 | 07:34 AM
Ok, maybe I'll go with 10.5 wide tires if I keep the stock wheels. But what if I went to like an 8 inch wide wheel? The stock alloys are 7 inches wide and have a 4.5 inch backspacing. What would be the equivalent in an 8 inch wide wheel? Something like 5 inches of backspacing?
Old Oct 25, 2018 | 07:48 AM
ev13wt's Avatar
5 Year Member
3,75" backspacing. 8". American Racing has some. 139mm, 6 Lug
If you like that Matchbox car look, go for it! I think 31 or 33 x 12.5 look like square blocks 37x12.5, that is ok again
Old Oct 25, 2018 | 07:51 AM
L5wolvesf's Avatar
Check Tire Rack for the tire(s) you are considering. The manufacturers usually show the recommended wheel width(s).
Old Oct 25, 2018 | 10:15 AM
SomedayJ's Avatar
33x9.5 to have more pressure on the road for wet condition? As far as I know, you don't have anything All Terrain style in that size in Europe. You can find the BFGoodrich MUD Terrain in 33x10.5 r15, and they're very noisy on the road and not good in wet road, the 33x10.5 r15 All Terrain're better in those conditions but they're discontinued here. There're more options in 31x10.5 r15, but not in 9.5.
If you can find the BFGoodrich in 33x10.r r15 (All Terrain), let me know, please.
Old Oct 25, 2018 | 11:57 AM
ev13wt's Avatar
5 Year Member
Just checked, offroadreifen com has over 20 in stock on the 33 10,5s MT. Can't find a AT. My dreams...
i messed up I meant 30x9,5r15
need to check metric options.
Old Oct 25, 2018 | 12:03 PM
SomedayJ's Avatar
Please, can you send me that link, I only see 33x12.5 r15. I can't find the BFG All Terrain 33x10.5 R15.
Old Oct 25, 2018 | 06:47 PM
Here's the link for those BFG All Terrains in 33x10.5r15 https://www.tirerack.com/tires/tires...=305R5KO2RWLV2
Just to clarify, an 8 inch wide wheel with 3.75 inches of backspacing would be equivalent to the stock alloy wheels that are 7 inches wide and have 4.5 inches of backspacing?
Old Oct 25, 2018 | 11:37 PM
ev13wt's Avatar
5 Year Member
No idea, If I calculate it, it would obviously be 4" to get in into the same center location, right?
3,75 works great though. No binding, no rubbing. A bit wider. Some like the look. Might need an inch of body lift or crank for the 33s. 33 10,5 will work pretty great on the stock sr5 rims
Old Oct 26, 2018 | 07:11 AM
Going to be getting 33s once my Blazeland long travel kit shows up, and he recommends those stock sr5 wheels because of the deep backspacing. With 3 inch wider control arms on each side, they should help keep the track width manageable. So basically I want 8 inch wide wheels that will put the mounting surface at the same spot as the sr5 wheels would so the truck isn't obnoxiously wide.
Old Oct 26, 2018 | 07:41 AM
ev13wt's Avatar
5 Year Member
3" per side? That would mean you need a 7" backspace front rim and a "stock" rear one. It would look cool too, the front has less depth than the rear rim, looking from the outside! I like.
Just make sure the front is a bit (1 or 1.5") WIDER than the rear. That will make it go straight much nicer.
Old Oct 26, 2018 | 07:42 AM
ev13wt's Avatar
5 Year Member
Steering ackerman angle will be fubared in any case, so go for what looks good and is close to each other in track width, front +1 to 1.5" wider.
Old Oct 26, 2018 | 07:15 PM
Plan was to have 3 inch wheel spacers in the rear to match the front width increase. Should I go with 1.5 or 2 inch spacers instead? This would make the front a bit wider than the rear.
Old Oct 27, 2018 | 01:19 PM
ev13wt's Avatar
5 Year Member
2"
Get both at the rear (2", 3") and tell us about it. Theory and real life testing are definitely two different things.
With a narrower rear, it "should" track smoother and follow the front with less sketchy breakouts.
Old Oct 28, 2018 | 05:55 AM
dropzone's Avatar
Fossilized
do you like to buy tires? like an even tire wear?
Best of luck finding a tire shop to mount them for you
do a T100 Rear axle to match your front track width
Old Oct 28, 2018 | 07:12 AM
Sounds like I should probably stick with 10.5 tires for the stock wheels then. It would be ideal to swap in a T100 axle, but I've already got gears and an ARB out back, don't really want to have to start over. From what I've read there shouldn't be any issues with wheel adapters in the back, seems like most guys running the Blazeland kit do and it works good for them.
Old Dec 13, 2018 | 08:18 AM
BMarino's Avatar
I was just reading this and other threads trying to get the correct info:
I'm currently running 31x10.5 BFG M/T on my '94 4wd pickup:
Have no idea on the specs of the current wheels (just bought the truck a few months ago), and I want to swap them for some steel wheels. I'm happy with the current setup (little extension beyond fender wells), would like to keep it as is. Truck is completely stock, no lift or other mods.
I'm looking into a set of steel Procomp 97 Series 15x8 with a 6 on 5.5 bolt pattern and 3.75 backspacing. Would these be the specs to go for?
Thanks!
Old Dec 18, 2018 | 08:50 AM
jakey poo's Avatar
You're going to have to get out the ole tape measure and measure up your wheels to see if the new ones will fit the same. Personally however I think the rims you have now look/fit great with the pickup.
