Is my truck supposed to run w/o TPS?
Old Mar 26, 2008 | 10:10 AM
91Toyota's Avatar
I unplugged my TPS since I am having some surging problems and my truck just idles higher (2200rpm) but doesn't surge. Does it sound like I need to adjust it? Where is the article thingy on where or how to do it?
Thanks!
Old Mar 26, 2008 | 10:19 AM
dcg9381's Avatar
Thanks!
TPS might impact timing - advance it and make it idle high.
Alternately you've got a vac leak.. I really don't know what will happen.
Search google:
4crawler TPS
Old Mar 26, 2008 | 10:26 AM
91Toyota's Avatar
Yep, I do have a vacuum leak. I can literally unhook the line that goes to the butterfly assembly to the front top of the valve cover and my truck does nothing. I can see a couple cracks and holes in a couple lines. But when I spray wd-40 or something my idle does NOT change...that is why I haven't done anything yet.
Old Mar 26, 2008 | 11:04 AM
MMA_Alex's Avatar
try starting fluid or something else that burns easier than wd-40 on the cracks..or just replace em.
the truck should run with the tps unhooked (your thread title question) but it'll run in hobble mode
Old Mar 26, 2008 | 03:42 PM
Matt16's Avatar
My truck ran and passed emissions with the AFM broken and unplugged.
Old Mar 26, 2008 | 04:01 PM
91Toyota's Avatar
I dont have emissions or a cat!
Old Mar 26, 2008 | 04:08 PM
1992toyota4x4's Avatar
ya i just finished my rebuild and i had thought that my egr gasket was leaking cuz i could hear a vac leak, and engine would studder bad at idle, turned out when i pulled the intake manifold off i forgot the hose that goes from the intake manifold to the pcv valve, well i forgot one side of it, found that problem tonight!
Old Mar 26, 2008 | 04:35 PM
DCYota's Avatar
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Mar 26, 2008 | 05:58 PM
iamsuperbleeder's Avatar
How does that work? Mine shuts off after about 1 second after startup with the AFM unplugged. I though they shut off the fuel pump or something... unless you jump those 2 wires to fool it...
Sorry for the hijack
Old Mar 26, 2008 | 06:22 PM
91Toyota's Avatar
its o.k, the thread was dead that the beginning anyway...feel free to ask!
Yont283
Sep 23, 2022 08:06 PM
zd92655
Mar 6, 2022 12:58 PM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
Land yacht
Jun 28, 2002 09:53 AM
