my first 3vz toy with many problems
Old Mar 9, 2021 | 05:04 PM
rasta Venezuela's Avatar
my first 3vz toy with many problems help please
Help with my 3vze my first toy never failed me so far. It all started when the distributor cap broke, which caused a loss of strength, since I was working with 2 less cylinders. Until it turned on no more, then I bought the Berk amkley brand cap (made in Japan) from Amazon of very good quality it seemed to me. The cover was placed, the denso spark plugs and cables of the same brand, the change was exceptional, I had a lot of time that the truck did not feel so good and after a couple of days the nightmare in which I find myself began.
1- the spark plugs get wet with gasoline and oil. They were cleaned every time I went out to the street so that the truck had good performance.
2- the consumption of gasoline and the smell of gasoline exhaust is daily. A full tank and lasts approximately 120 miles.
3- the mixture of gasoline with the engine oil that becomes contaminated.
4- loss of force in the motor. Partial solution I decided to clean the injectors, change air filter and change the engine oil, filter and clean PCV valve vacuum lines and intake body.
After this I improved a lot and my engine stabilized as always with slow but sure force. Until today I check as usual before leaving the house because I notice a water consumption that is not normal and I am at the point where the engine oil and the water are mixed. I no longer know what to do, I appreciate receiving advice and possible guidance to be able to solve this since this is my only vehicle and that is what I work with on a daily basis.Greetings to all from Venezuela and I am very grateful who can guide me why I no longer see what solution there may be and what caused all this since the truck did not overheat or anything.
all this is clean
all this is clean
all this is clean
This is in the problem that I am now and I do not understand why
Old Mar 9, 2021 | 05:08 PM
millball's Avatar
Blown headgasket
Old Mar 9, 2021 | 05:19 PM
Gracias por tu orientación
Ok. millball ok what he tells me is that the gasket of the camera was damaged and I have to change it. I recently bought a set of gaskets through amazon which I mount the Evergreen brand and it must not have 25,000 miles of truth I do not understand why this happened to me but I will lower the camera or what they call it here heads I will change the gaskets and comment how I'm going I hope that it does not happen to greater as a breakage of a ring or something else and soble the cotamination of the oil with the gasolina that you could guide me.
thanks for your prompt reply
Cody91
May 1, 2011 08:17 PM
StangBanger
Sep 10, 2009 06:06 PM
PirateMcgee
Nov 13, 2008 10:24 AM
just a 22re
Jul 13, 2008 04:02 PM
Strider7
Aug 28, 2006 02:41 PM
