My a340h shifts at 4000 any way to make it hold gears longer?
Old Dec 17, 2012 | 05:49 PM
david braun's Avatar
Originally Posted by snap-on
pull shift lever down to "2"
on a side note, all of the dyno runs ive seen for stock 3vze and 5vze peak at about 4200 rpm and drop off from there. dont know that you will gain much above 4000rpm anyway in terms of performance for stock engine.
That's the answer I was looking for I have other problems that I'm trying to fix but that's just one last thing to worry about
Below is one of them
http://youtu.be/M57MrrZ3NOo
Old Dec 28, 2012 | 09:36 PM
well i was up tonight watching youtube videos came across this..
and also an update, got my obd2 hooked up and i got 8 codes more then half where related to the rear o2 sensors evap pressure sensor and coolant temp sensor..
i have already replaced the coolant sensor and upstream o2..
i did get a tps code that i may have fixed when i tested it i bent one of the prongs off to the side..
what i'm worried about is the p1700 code= speed sensor... i believe that to be the big problem..
i talked to the po and he said he didn't hook the speed sensor up for the tranny because the sensor isn't compatible with the newer 98 ecu!
any way to get around this?
cant do a 5 speed swap for a while and swapping to a a340f isn't gonna happen..
ill be getting another od2 reading monday
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
