Mustang Seats in 93 Pick-Up
Old Dec 31, 2010 | 02:15 PM
irab88's Avatar
i searched and searched, but could not find any info on how to install ford mustang bucket seats. it was more of an urban legend than anything else. however, after a good day of work, i finally got the driver's seat to fit.
first i took the brackets off of both seats. the mustang seat:
here you can see the mustang bracket (back, with all the motors), the yota bracket (the pair of tracks), and the yota seat:
the mustang seat had holes that lined up almost perfectly. just needed to tap them:
so i did. i was surprised that they were metric bolts on the ford seats:
some minor enlargement of the hole was necessary:
i needed to extend the adjustment lever. more on that later:
here's the yota bracket on the ford seat:
and how all the holes lined up:
front left:
front right:
back left:
back right:
almost a direct fit. at least i didn't have to make anything too complex or heavy. the brackets that were made were tiny:
a square hole to accommodate the carriage bolt:
and how they're mounted:
they go on first, followed by the seat:
and they're out of the way:
now, for the handle. i had to extend it, so the first thing to do was cut it:
then i found some tube that just fit around the outside:
and welded a small piece on the handle side. this is before mounting it:
finally, a hole was drilled and a bolt inserted. that was the last step (besides re-installing the seat):
and the final product:
compared to:
the passenger seat will be slightly different, but the same concept
Old Dec 31, 2010 | 02:29 PM
Nervo19's Avatar
Thanks for the great writeup. The new seats look very comfortable. Have you found any good junkyards in NOVA? I live in Richmond.
Old Dec 31, 2010 | 02:30 PM
Swimmerboy2112's Avatar
Very nice! I need to get me a new set of seats.
Old Dec 31, 2010 | 03:43 PM
irab88's Avatar
the seat is soooo comfy. less spring, more cushion. i think i adjusted it 5 or 6 times coming home from my friend's place
ha, no. you probably are closer to fredricksburg than i am, and i hear there's some good ones down there. but all the mexicans take the good yota parts around here, so it's slim pickin's.
and continuing with junkyards, i need to pick up more seat brackets. the passenger seat (toyota) is completely different from the driver's. i need to either pick up another driver's seat bracket or passenger's from a bucket. anyone have pics of the underside of a passenger bucket (sr5) or something like that?
Old Dec 31, 2010 | 06:10 PM
JamesD's Avatar
What I would HIGHLY suggest is to get rid of that carriage bolt and upgrade to a grade 8 bolt. I bet that bolt would shear off in an accident but other than that cool job!!
James
Old Dec 31, 2010 | 06:45 PM
irab88's Avatar
James
thanks.
yeah, the zinc plated stuff will be gone soon enough
Teuf's Avatar
Irab, you dah Man, great write up and pics.
Old Dec 31, 2010 | 06:56 PM
Moonfish's Avatar
The little strap thingies will move and bend long before the bolts break. I can't see why he didn't just bolt them through? I'm not sure how much the seat bolts really hold because if you crash, the seatbelts will do 98%.
Oh and thanks for the pics. They are the best ones I have seen. And confirming you need more seat rails if you have the stupid bench.
Old Dec 31, 2010 | 06:58 PM
Teuf's Avatar
Seats don't weigh much, there not going anywhere.
Old Dec 31, 2010 | 07:30 PM
1shortfoot's Avatar
Looks good,Like the Ford seats.I put in seats from a Camary had to do the same. Execpt my yota came with a bench seat.However same type of fab work.
Old Dec 31, 2010 | 07:44 PM
Teuf's Avatar
I love my sr5 buckets, but dang I miss the ole bench.
Old Jan 1, 2011 | 07:37 AM
waskillywabbit's Avatar
It's not the seats that are going to die in a crash. It's the melon heads sitting in them that don't understand simple physics and kinetic/potential energy.
:wabbit2:
Old Jan 1, 2011 | 08:10 AM
irab88's Avatar
as soon as i find a good source of grade 8 carriage bolts, i'll have them in. in the meantime, i'm sure they'll be just fine
also, if anyone has the rails from a 60/40 driver's seat, i'll take them.
Old Jan 1, 2011 | 08:24 AM
toyospearo's Avatar
Nice work!! Looks great.
Old Jan 1, 2011 | 09:28 AM
irab88's Avatar
thanks!
ok, i have searched. and then some...
where can i buy grade 8 carriage bolts????
either they're an urban legend or i can buy them in packs of 100+ (for $100+)
Old Feb 19, 2011 | 12:03 PM
irab88's Avatar
just an update on the seats: i have yet to find grade 8 carriage bolts. i got into a little fender-bender, and nothing came loose, broke, or shifted
also got the lumbar support to work. just a few feet of wire and finding the right place to put them. i still need to run them under the carpet, but at least they're under the mat
and whenever i do the passenger seat (no, still not done), i'll be sure to post that up here as well
Old Feb 19, 2011 | 08:57 PM
Aron9000's Avatar
What year Mustang are those seats out of? Cause I've always thought the SN-95 and New Edge Mustangs(94-2004) had the most uncomfortable seats ever. Even worse than the bench seat in my reg cab 93, which doesn't lean back.
Old Feb 19, 2011 | 09:11 PM
ChefYota4x4's Avatar
front left:
front right:
back left:
back right:
compared to:
Had to scope this out again,......really got me thinking of "fish for seats at the yard til a drop"-fest this summer! lol.
I've heard the SC300-400 seats are REALLY nice, ......and the 96+ 4Runner Seats as well. I'd REALLY like to do this mod/swap, fo sho! lol.
Just wanted to re-"KUDOS" ya for the great job and write up, Ian... Nice!
Old Feb 20, 2011 | 05:48 AM
irab88's Avatar
thank you for making me look it up. i've needed to do that for a while.
they are out of a 94 mustang gt. i like them, they're more comfy than my 60/40
the only thing that could be better it the head-rest. it could stand to be moved a few inches forward. that's all. but these seats are so comfy that i've fallen asleep in them easily.
now that i know how easy it is to swap seats, i might look at other seats that might be in a little better shape, or not... i dunno
Old Feb 21, 2011 | 12:42 PM
92 flatbed's Avatar
I took my seats out of a 1989 mustang.... they are blue, just like the truck interior, and look like they belong there
