Mustang Seats in 93 Pick-Up
Old Feb 21, 2011 | 12:56 PM
blake.nemitz's Avatar
i gotta ask how did you cut those square holes
Old Feb 21, 2011 | 01:46 PM
irab88's Avatar
with a square drill bit, of course!
naw, it was a round hole with a bit of air file
Old Feb 21, 2011 | 02:18 PM
kevtek's Avatar
Nice job, looks good.
Old Feb 22, 2011 | 12:18 PM
irab88's Avatar
thank you!
it'll look even better once i get the second seat in there...
Old Feb 23, 2011 | 08:13 AM
  #25
92 flatbed's Avatar
those look even nicer than the 1989 mustang seats I put in, I am sure you will be happy with them. Nice job...
Old Feb 23, 2011 | 01:12 PM
  #26
Aron9000's Avatar
So to the OP, is that 40/60 split bench a direct bolt in for a non-lean back bench in my 93 reg cab? Cause if its in good shape and the bottom cushion still "cushiony" I might take it off your hands.
Old Feb 23, 2011 | 01:45 PM
  #27
infamouslyb's Avatar
very nice job.
Old Jun 11, 2011 | 02:07 PM
  #28
irab88's Avatar
update: this weekend, i'm working on getting the second seat in. it's more tricky than the last. i made a bar that goes along the back with two bolts welded up. in the front of the seat, only one hole lines up. so i'm making a small bracket for the other side. the tracks mount to the seat in the exact same way the driver's seat does. i'm even going to re-install the driver's side slide adjustment lever, as it's loose now.
and before someone says: "pics?"--- i'll have them up tomorrow or monday
Old Jun 12, 2011 | 04:07 PM
  #29
irab88's Avatar
time for pics:
getting the rails to fit the seat is the same as the driver's side: tap the furthest back holes and elongate the track holes slightly. then extend the adjustment lever. (i re-mounted the driver's side because it was loose. it's the uglier of the 2 welds)
slight bending of the cross-piece
and the modified adjustment levers
ready to paint
now for the brackets i used
the one hole that lines up. it's the highest, so i had to use it as the start point to use as few brackets as possible
aaand paint (self-etching black)
trimmed bolts
and now to install
ta-da!
and i tried moving the driver's seat, but it sat diagonal and lop-sided, so i just painted those brackets, too
Old Jun 12, 2011 | 05:24 PM
  #30
xxxtreme22r's Avatar
Looks good, I still want your split bench !!!!!
Old Jun 12, 2011 | 05:33 PM
  #31
irab88's Avatar
driver's side ain't got no rails, but i could bring the seats up to rausch creek if you want them... gotta check something first, though
Old Jun 12, 2011 | 05:37 PM
  #32
No money and I am almost afraid to mess with the seat hardware due to what my frame looks like.
Old Jun 12, 2011 | 05:46 PM
  #33
irab88's Avatar
all the seat stuff is inside the cab. unless your floor is wet when it rains, there shouldn't be too much (if any) rust. i never painted the first brackets i made, and they never rusted in the cab, mounted. i bet your bench is fine, too.
Old Jun 12, 2011 | 08:27 PM
  #34
yeehaw1's Avatar
seats look great irab, that reminded me that i need to finish bolting my 60-40 seat down, and also, it's time to start looking again...
Old Jun 13, 2011 | 05:31 AM
  #35
irab88's Avatar
thanks yeehaw. i need to get a picture up of the two with both seat covers on (they look ok as-is, but they match). it's nice to finally have a matching set
next on the list: i might put the jump seats back in... not sure yet.
Old Sep 2, 2011 | 01:05 PM
  #36
irab88's Avatar
jump seats will go back in later this weekend.
cleaned up a bit today, so here's a good shot of the swap done:
Old Sep 2, 2011 | 05:54 PM
  #37
AZ89LONGBED's Avatar
Looks great!
I wonder how those seats fit in a regular cab? Especially for the taller folk. How much did you pay for the seats?
Old Sep 2, 2011 | 06:23 PM
  #38
irab88's Avatar
hair over a hundred. the guy i bought them from wanted 150 for the front and rear, but i talked him into just the fronts
i don't know if these will work too well with a single cab, but if someone wants to come over, it'll take 5 minutes to swap the seats and find out. i'm about 6'2" and these seats are comfy. i've fallen asleep easily (never while driving). love 'em.
Old Sep 2, 2011 | 09:31 PM
  #39
ChefYota4x4's Avatar
Looking nice, man! Wow, that's a good looking interior.... Love the Shifter Set up(w/out the console section like my 4Runner has).... it looks CLEAN!
Seat covers are nice, enjoy!
PS> I keep hearing that 90-95 4Runner seats bolt RIGHT IN on my rig.... Even found a thread. Just trips me out, as I've measured the bolt holes twice and could have SWORN it was different! lol.
Old Sep 3, 2011 | 11:58 AM
  #40
yeehaw1's Avatar
Those seats look fantastic man, i've got to ask though, what model mustang were those out of? I've been looking for three months for a set and still haven't found them. I'm starting to get that itch to finish the truck since i got new front fenders.
