Misfire : 3VZ
Old Jan 1, 2011 | 06:11 PM
BigGreenZ_71's Avatar
The tank is rusted bad due to sitting around for 2 years before I bought the truck. It had a bum motor, put a long block in and now i'm having to fix the tank.
Old Jan 1, 2011 | 06:18 PM
camo31_10.50's Avatar
gonna be replacing my fuel filter soon, and at the same time taking my upper intake manifold off to track down the leaking gas :/
hope my tank aint nasty
Old Jan 1, 2011 | 07:56 PM
808-3VZE's Avatar
I see. Just like mine the truck was sitting around for about 2 years also. The previous owner put in a lower mileage 3vze that the recall was done. Found out that the engine had 70,xxx. Original miles. So I had to do was the fuel system and she was good to go.
Old Jan 1, 2011 | 08:00 PM
808-3VZE's Avatar
I hope so too! Finding a tank for me was a bitch. Hope u fix it
Old Jan 1, 2011 | 08:29 PM
  #25
BIGR79's Avatar
mine had a studder till about 3500 rpm, I took all injectors out and bench tested them and they all opened and closed as they should, but with motor running I found a hole that at idel when pulling of plug wire it wouldent change the idel like the other 5 would, so I pulled that injector out and replaced it and now its running like a champ,
thats what i would do if i were you, start pulling wires with it run ning and make sure each wire when pulled changes your idel
Old Jan 3, 2011 | 01:04 PM
  #26
easy on the language buddy, they'll write you up for it.
I'm going to get the upper intake off in just a little bit, gotta clean my ducks first
Old Jan 3, 2011 | 01:47 PM
  #27
REDYOTA's Avatar
Muriatic acid works good on messed up tanks
Old Jan 5, 2011 | 01:35 PM
  #28
took off my upper intake manifold and wellllll.........
my hardline at the back of the manifold that is bolted to the passenger side head (the one coming from the tank) has a dent in it, and i think it might be cracked..idk..haven't looked that far yet.
i noticed OIL on the lower intake manifold, on the driverside of it..right where my knock sensor wire goes under the manifold......wtf could this be? Valve Cover Gaskets????? that's the only thing i know of!
Keep in mind, there is some Coolant mixed in with it..it drained outta my upper intake manifold as i was taking it off..it's definitely oil though.
Here's a closer pic
in the first picture at the "Hole"/"notch" in the head bottom right hand corner of the pic, you can see more oil.......theres oil in another "hole"/"notch" on the passenger side as well. but this oil is not in all of these "holes". just a couple
i really hope it's my valve cover gaskets.........
Old Jan 6, 2011 | 09:56 AM
  #29
Bump to the top
Old Jan 12, 2011 | 03:45 PM
  #30
okay SOOOO
turns out my Driver side Valve cover gasket is totally SCREWED....looks like it wasn't in the groove all the way??????? Screw up on my part
new Vavle cover gaskets, intake manifold gasket, new radiator cap, and some more coolant along with a repaired fuel line going in tonight/tomorrow.
my Missfire is coming from a fuel leak i believe....my main hardline right there by the passenger side fuel rail has a small dent in the side of it..and it leaks a little right there...gonna see if i can fix it, if not i'll rob one from a parts runner at a junkyard
i'm hoping that fuel leak will be the end of my "Misfire" issues
Old Jan 13, 2011 | 09:57 AM
  #31
REDYOTA's Avatar
go ahead and grab a replacement, as well as some new pcv hose for the pass side, 1 dollar for some fresh stuff. while your there clean your injectors and buy some new orings for them i mean your right there go ahead and clean them and the rails and blow some air through that front portion of line from the filter to the rail. $5 for a fresh fuel system. get real crazy and spend $15 more replace the filter drop the tank and blow through that line from the front to the back. Go insane and buy a strainer for the fuel pump pull it and clean the whole thing for less than $50
Just make sure you put some grease on the orings before you put them back in the rails.
Old Jan 13, 2011 | 10:08 AM
  #32
ROFL i just put the o-rings on there like 1500miles ago...lmao
it'll be fine until another problem shows itself...don't fix what aint broken
Old Jan 13, 2011 | 10:13 AM
  #33
REDYOTA's Avatar
heard that. didnt know where you were on it. i forced my used orings in my rails with no lube a while back when I reworked my fuel system buttoned it up jumpered the pump to prime it and splish splash gas all over the place. good luck with it and hope you get her evened out tonight.
Old Jan 13, 2011 | 10:16 AM
  #34
i didn't lube mine, but all went in just fine, my leak was CLEARLY at the main fuel line, now that i have it off the truck, i can see the crack that's in it.
Old Jan 14, 2011 | 06:16 AM
  #35
808-3VZE's Avatar
Hope u fix dat problem camo! Changing injectors on a 3vze is a bitch! I'm glad I did all six of them at one time. I lubed up my injectors with a little grease and went in fine. Put everything back together started it up and no leaks! Lmk how it goes bro!!!
Old Jan 14, 2011 | 08:56 AM
  #36
well right now i'm waiting on a replacement fuel line..(apparently the ones from different year 4runners are different....) so everything is on hold..
got my Valve covers cleaned up, put on, and ready to go though!
this new Felpro Intake manifold gasket is THICK..my old one was like, just straight paper....this new one feels like an exhaust gasket (weight, thickness wise) and is super nice!
Old Jan 14, 2011 | 10:25 AM
  #37
MudHippy's Avatar
i didn't lube mine,...
Originally Posted by 808-3VZE
I lubed up my injectors with a little grease...
Just in case someone comes across this thread and would like the correct procedure for installing the injector o-rings to the injectors, and injectors w/o-rings to the fuel rails(delivery pipes), the FSM states as follows:
16. INSTALL INJECTORS AND DELIVERY PIPE
(a) Install a new grommet to the injector.
(b) Apply a light coat of gasoline to a new O–ring, and install it to the injector.
(c) While turning the injector clockwise and counter–clockwise, push into[sic] the delivery pipe.
http://personal.utulsa.edu/~nathan-b...68cylinder.pdf
Grease can harm certain types of rubber, particularly soft rubber like the injector o-rings. Not a smart move.
Old Jan 14, 2011 | 10:55 AM
  #38
REDYOTA's Avatar
Damn your aggrivating, how can you quote the fsm on folks and yet put wine corks in your plenum, hack your egr out, and gut your cat. You find that in the fsm too.
Old Jan 15, 2011 | 07:18 PM
  #39
he's right though, gasoline won't hurt them, and it will make the rubber swell up a little bit.
Old Jan 16, 2011 | 07:55 PM
  #40
REDYOTA's Avatar
I know that's what makes it aggrivating
