Mass Airflow Sensor
Old Mar 20, 2014 | 11:34 AM
Tmiller57's Avatar
Originally Posted by slosurfer
somebody should take a pic of those screws and sticky it saying "do not touch"
I'm having trouble with the air flow meter. Truck fires fine but then dies out quick. If I hole the door of the air flow meter open it runs fine. Any idea what would cause it to malfunction? From what I'm reading people say they don't really go bad. 91 3.0 v6
Old Mar 20, 2014 | 12:38 PM
Gevo's Avatar
Sounds like it's bad. UNLESS, the top has been opened and messed with. If it just started to have these symptoms I doubt it's an adjustment issue. Was the plug pulled out?
Ues the FSM to test the resistance of the various circuits through the connector.
Old Jun 16, 2014 | 07:54 AM
nanner's Avatar
pulled the guts out of maf meter too
looking for a picture of the inside of one to make mine is back together right can any one help me out? thanks
Old Nov 1, 2019 | 10:11 AM
Madrid's Avatar
Originally Posted by mt_goat
Probably, the MAF measures the air flow my estimating its mass (small heated wire cools with air flow) , the AFM measures the air flow by volume (spring loaded flap door opens wider with more air). The "V" must stand for volume.
this trk has AFM NOT MAF.. CAN IT BE CLEANED OR DO I NEED TO REPLACE THE WHOLE PART
Old Nov 1, 2019 | 10:45 AM
  #25
keycw's Avatar
5 Year Member
ignore this I cant figure out how to delete a post
Old Nov 1, 2019 | 11:26 AM
  #26
old87yota's Avatar
Regular users cannot delete posts (except maybe in the classifieds section? Not sure...). You used to be able to delete your own posts as some very old threads indicate some posts that have been deleted by that user.
Swimmerboy2112
10
Jul 16, 2013 10:52 AM
kato
12
Aug 15, 2009 05:04 AM
nate V
Jan 3, 2008 03:31 PM
Greedy
Dec 28, 2004 02:50 PM
my95toy
May 9, 2003 06:49 PM
