Many questions about rebuilding a 22RE
Old Mar 3, 2011 | 05:29 PM
yotarover's Avatar
btw anybody had trouble with the top passensger side bolt on the rear of the engine bolting the trans to the engine. i've tired putting all the bolts back in and just taking it off *nothing is turning that thing* i went at tring to cut it off by attempting to crack the block around it *it's already blown with a huge hole it's the whole reason why im building a new engine*. wish i woulda bought a plasma cutter
Old Mar 4, 2011 | 03:38 PM
yotarover's Avatar
which bolts go where tc, oil pump
i gotta replace most of my bolts so which of these go where feel free to photoshop
yes i wrote it down as i took it out but everything is missing
Old Mar 4, 2011 | 03:45 PM
xxxtreme22r's Avatar
the ones with the sleeves look like the timing chain guide bolts.
This diagram might help ya out too:
the top bolt on the oil pump on that diagram is not labeled and it's important that it's not too long. SHould not go through more than this:
Old Mar 4, 2011 | 04:00 PM
yotarover's Avatar
thanx for the replys
Old Mar 22, 2011 | 07:42 PM
  #25
yotarover's Avatar
22re connecting rods/.40 pistons
I'm building a new engine. Already had the block bored .40 over; can i use the stock rods with my new pistons? Along with a new toyota journal crank shaft from LCE.
Parts i have:
New lce crank shaft (toyota journal)1013036
4 new Stock Rods
4 new .40 pistons+ master kit from EB
new water pump
egr block off plates
Parts needed
header
head/cam/bolts
tc/oil/water bolts ( dunno what happened to them their just gone)
oem/felpro hg
3 a340h solenoids and a rad shifter (raddesigns)
Old Mar 22, 2011 | 07:45 PM
  #26
yes as long as the LCE crankshaft is the toyota journal as you say.
pretty sure you will need different then stock bearings though. "We precision grind each crank to .25mm (.010") under size on both the main and rod journals. "
Old Mar 22, 2011 | 07:54 PM
  #27
yotarover's Avatar
thought i would ask. Before i started to put the bottom end together.
Old Mar 22, 2011 | 07:57 PM
  #28
just double check the bearings, I doubt stock sized bearings are gonna fit LCE's crank. Check with LCE.
Old Mar 22, 2011 | 08:02 PM
  #29
yotarover's Avatar
why i didn't check before i ordered.
Old Mar 22, 2011 | 08:11 PM
  #30
looks like you'd need .10 oversized main and rod bearings if I read their description right?
Old Mar 22, 2011 | 08:14 PM
  #31
yotarover's Avatar
yeah i just went to their site and checked, i didn't order it from them i got it from a freind at his local shop
Old Mar 22, 2011 | 08:40 PM
  #32
yotarover's Avatar
i know this isn't the classified's but if any of you have a stock crankshaft sitting around. don't mind selling it pm me
Old Mar 22, 2011 | 09:00 PM
  #33
why not just get bearings for the crank you have? Looks like you might be fine with STD thrust washers though. You can get em from LCE or look for the .25mm sized rod and main bearings. I wouldn't get a crank from someone else unless you plan on having it checked/machined. The LCE crank you got is probably one of the better ones out there.
http://www.toyotacatalog.net/M1WebGe...3-bf6061430967
http://www.toyotacatalog.net/M1WebGe...5-8A06EE3E0ECC
Old Mar 22, 2011 | 09:38 PM
  #34
yotarover's Avatar
i have 2 blocks. thought i'd go ahead and build both (dont wanna pay another 200+ for another crank) if somebody has a stocker. (i'll have it checked at the machine shop as well)
Old Mar 23, 2011 | 03:18 AM
  #35
this is the one I have in my truck. 10,000 miles and no issues as of yet. $165 free shipping. Packaged well, just remember to clean off the anti-rust lube/grease with mineral oil before assembly. I plastigauged before assembly everything was within spec. I can't remember the manufacture off hand though. I wana say ITM, but not 100% sure.
http://cgi.ebay.com/ebaymotors/Toyot...Q5fAccessories
This is the direct link to their site, it's actually cheaper on their ebay listing. on sale right now I think. $152 on ebay $160 on their website.
http://www.japanengine.com/products/...&search=&page=
I think I saw a few used ones as well on ebay.
Old Mar 24, 2011 | 07:36 PM
  #36
yotarover's Avatar
Block removal issues
I got the block tore down. All the bolts removed from the tranny to block except one that wont turn just round off. Attempted to cut out with cut off tool no luck; so i took a RR spike to the cut and a BFH. went to finish taking out the block and it wont come back,out, but moves around *yes the mounts are off and exhaust*
Old Mar 24, 2011 | 07:39 PM
  #37
jd20phill's Avatar
pull harder? No, but in all seriousness, did you remove the torque converter bolts?
Old Mar 24, 2011 | 07:56 PM
  #38
yotarover's Avatar
every bolt around the back is gone
Old Mar 24, 2011 | 09:34 PM
  #39
yotarover's Avatar
on the drivers side where the bell housing and tranny bolt together. there is a bolt right behind one of the main bolts, i took it off. tried jacking up the blocck from bottom and pulling forward then winching up. still aint moving or even trying to seperate
Old Mar 25, 2011 | 01:53 AM
  #40
yotarover's Avatar
will the block slide out though the tunnel with the tranny *backwards over the differential* plan: take off engn mounts from block, undo drive shafts and yank it out. i have a 2"bl and can raise up the cab more if i have to just wanted to know it a bare block with pan will go out backwards
