manual hubs question
Old Dec 27, 2012 | 02:01 PM
  #41
seabee 86's Avatar
Okay so I would like to add a question here. I have an 84 4Rustbucket in my back yard with a solid front axle and manual locking hubs. I'm finding conflicting results and am hoping for a clear cut answer (if there ever is one...) will the hubs from a SFA fit into the IFS? Looking on various forums some posts say they're the same, others say they're different. Thanks!
Old Dec 27, 2012 | 02:03 PM
  #42
seabee 86's Avatar
I think I answered my question. WABFAB has two different hubs for SFA's and IFS. Dammit.
Old Dec 27, 2012 | 02:05 PM
  #43
waskillywabbit's Avatar
Bingo.
Look here
http://www.se4rj.com/forum/forumdisplay.php?f=19
:wabbit2:
Old Dec 27, 2012 | 02:17 PM
  #44
seabee 86's Avatar
Okay so here is my next question. I have Automatic Locking Hubs (at least that's what the center piece on the wheel says). Say I'm in 4L and put my truck in reverse. How do I re-engage the 4WD? Do I have to put it into 2L, then back into 4WD? Or will it automatically re-engage itself just by driving forward?
Old Apr 29, 2013 | 06:11 AM
  #45
wolf28's Avatar
well a buddy of mine has a set of manual hubs for 60 bucks I think I might buy them and put them on
Old Apr 29, 2013 | 06:22 AM
  #46
StewsRunner's Avatar
What condition are they in? I recommend buying a few spare seals with them..
Old Apr 29, 2013 | 03:37 PM
  #47
wolf28's Avatar
spare seals?
he said good condition ill have then on the 20th of may
Old Apr 29, 2013 | 05:04 PM
  #48
Sturmcrow's Avatar
There is a star shaped seal under the dial face, an o-ring on the dial, and a round seal under the whole manual hub deal.
It is a great idea to replace the seals when you do this job. Otherwise water and crud get in there, destroys your grease, and you need to do it all over again.
Old Apr 29, 2013 | 05:13 PM
  #49
wolf28's Avatar
Is there a seal kit or are they all individual
Old Apr 29, 2013 | 07:58 PM
  #50
RJR's Avatar
RJR
Seabee86, the auto hubs work in both forward and reverse; don't let anyone tell you otherwise. They lock when the cv drive axle turns a quarter turn in either direction, and stay locked until the WHEEL turns 1/4 turn in the opposite direction. So, if you back up in 4wd, the hub will unlock after the wheel turns ¼ turn, and then relock after the cv axle turns another ¼ turn in reverse.
So, as you alternate directions, the hubs alternately unlock and relock. That's a big reason why lots of people don't like them. That, and the extra complexity of the internal mechanism.
RJR
Old Apr 30, 2013 | 07:12 AM
  #51
Sturmcrow's Avatar
Round gasket = 43422-60010
Star gasket = 43531-60010
O-ring = 43532-60010
From toyotapartszone.com two of each will run you $11.40 + shipping.
Old Apr 30, 2013 | 08:08 AM
  #52
Yotard's Avatar
Here is all the info you need I used this when I swapped mine with Warn hubs from the stock ADD hubs.
https://www.yotatech.com/forums/f128...4runner-76320/
Old Apr 30, 2013 | 04:09 PM
  #53
wolf28's Avatar
do I need the gaskets or can I use rvt
Old Apr 30, 2013 | 04:56 PM
  #54
arlindsay1992's Avatar
Do things right. Buy the gaskets.
Old Apr 30, 2013 | 05:31 PM
  #55
wolf28's Avatar
well took apart the hubs to clean them up and put new grease in them and the springs came apart in one and the other dial doesn't turn all the way. this things are a PITA for being hubs I have no clue how put the springs back together
Old Apr 30, 2013 | 07:33 PM
  #56
wolf28's Avatar
well I finally got the springs back together after some time working on them
next question what kind of grease should I use to grease these
glowz825
Jan 25, 2022 09:28 AM
oldirtydirt
Feb 23, 2020 09:30 AM
PlayAwhile
Jul 20, 2015 11:36 AM
rushw
Jul 18, 2015 01:46 PM
ItsJustD
Jul 7, 2015 07:49 AM
