Macgyver style trail repairs!
Old Aug 31, 2008 | 12:41 PM
  #41
algranger's Avatar
one time i snapped a rear leaf and i put a phone book on the bump stop to keep the tire from rubbing on the fender while i drove home
and just a tip for all of you on a budget.. dont remove your overloads and shave your bump stops
Old Aug 31, 2008 | 01:28 PM
  #42
Lysmachia's Avatar
I like the radiator fixes. Why didn't you guys just pinch off the fins where it was leaking or was it more complicated than that?
Troy and I carry a lot of bolts, pipe chims and washers for those crazy you never know repairs like u bolts breaking or leaf springs. I've helped a truggy limp off of posion spider with wratchet straps and chain because the shackle mount for the leafs ripped off. That was pretty crazy. I like these suggestions. Ya just never know how inventive you can be when stuck in the middle of no-where!
Old Aug 31, 2008 | 02:21 PM
  #43
algranger's Avatar
Originally Posted by SpecialScottie
I made a wallet outta duct tape once. Worked well
i had a duct tape wallet for like 4 years
Old Aug 31, 2008 | 02:59 PM
  #44
76ANTHONY's Avatar
Originally Posted by toy89yota
why work you be scared that im an aircraft mechanic.
do you work on hueys or just have a medivac huey pic? was in the military a whillllllle back and was a 67n
Old Aug 31, 2008 | 03:20 PM
  #45
abecedarian's Avatar
seems my rad leaks always occur on the end tanks, or at the seam between the core and the end tanks, not just my yota, but every radiator on every car I own has leaked within a couple of years of owning it.
so I've got lots of the pepper packets from drive-thru joints in the glove box just in case. it always seems to work on the pinhole leaks.
I've also heard cracking an egg into the radiator helps on some of the leaks too, but i've never tried it.
Maybe an egg, some pepper, and jimmy dean sausage links cooked on the exhaust.....
Old Aug 31, 2008 | 04:27 PM
  #46
toy89yota's Avatar
yep couple of the last hueys around, our last vietnam pilot just retired on friday, sadly the hueys will be leaving us too. Its too bad because they are the toyota of helicopters, very little maintenance needed to keep them up, very reliable, more fun to fly in then black hawks. Hawks are like fords, junk. hueys are easy to work on too kinda like an old chevy.
Old Aug 31, 2008 | 04:55 PM
  #47
gte718p's Avatar
b/c you said you use rescue tape in the shop all the time. Im not sure I trust the stuff on my rig much less and aircraft!!!!
Old Aug 31, 2008 | 10:52 PM
  #48
toy89yota's Avatar
we use it on wiring especially antenna connector ends. really keeps the moisture out so the avionics keep working. ours inst called rescue tape i don't remember what its called but its the exact same thing.
Old Sep 1, 2008 | 09:18 PM
  #49
annoyingrob's Avatar
So, what I'm getting from this thread is that I need to go buy some more ratchet straps.
I once had the A/C system fail 500km away from home on a very hot summer weekend, and my windows didn't roll down. I wired the A/C compressor right to the vehicles accessory power, through an extra switch I had in my dash, with some extra wire I had in my trunk. It worked so well, It's still in place.
I also had an inner fender liner come loose, and start rubbing against the tire. I pulled over, poked some holes in it with a knife, and tied it up with (the same) extra wire I had sitting in my trunk.
Old Sep 1, 2008 | 10:18 PM
  #50
SpecialScottie's Avatar
Just today my friends front driveshaft fell out on his samurai. He just installed RUF and didnt know that his spacer wasnt long enough. We were quite aways away from any tools so we tied it up with a belt
Old Sep 2, 2008 | 10:53 AM
  #51
tc's Avatar
tc
Ratchet straps are very useful for repairing stuff that's in tension ... stuff that's in compression (like say tierods) is WAY more difficult to McGyver ...
Old Sep 2, 2008 | 08:40 PM
  #52
slayyerr's Avatar
i was at the sand dunes in san nicholas in mexico and my yota was runnin on 3 cylinders and i couldnt figure out why, so i changed out the spark plugs, wires, and checked out everything i could. THEN i figured out it was the fuel injector clip that broke and wouldnt stay on. so i grabbed a couple zip ties and zipped them on(to this DAY the zip ties are still there holding the clip on)
Old Sep 3, 2008 | 08:28 AM
  #53
toy89yota's Avatar
might want to fix that
Old Sep 3, 2008 | 06:26 PM
  #54
TOYOTA 1's Avatar
if its not broke dont fix it, lol
justdifferentials
14
Jun 11, 2017 08:36 PM
djpg2000
Sep 7, 2015 10:36 AM
Ryall
Sep 2, 2015 06:48 AM
