low and spratic oil pressure???
Old Apr 25, 2009 | 08:37 PM
freebird_775's Avatar
Unhappy low and spratic oil pressure???
when im driving at about 2k-3k rpm the oil pressure needle is usually right in the middle, but some times when im driving the needle starts to drop when at a constant rpm and it gets to the first line in the gauge. but then the needle will barley move if i stop and take off and get back to 2k-3k rpm. i'm puzzled about what it could be. some one told me it could be a bad pressure relief spring?
also,when im cruising the trails of doing a little mudding and i get to 4k rpm where should the needle be a high rpm?
-thanks.
Old Apr 25, 2009 | 08:47 PM
algranger's Avatar
Mine sits half way at anything above 2500 rpms
Old Apr 25, 2009 | 10:32 PM
gary96360's Avatar
mine sits at quarter while idling. when im driving its at half
Old Apr 26, 2009 | 06:50 AM
ok thanks
i still cant figure out why it fluctuates when im at a constant speed
Old Apr 26, 2009 | 11:47 AM
Dirt Driver's Avatar
Hook up a real gage and then you'll know whether you have a problem or not.
Old Apr 26, 2009 | 11:51 AM
TOYOTA 1's Avatar
x2 on getting a real one! though its probably just a bad sending unit.
Old Apr 26, 2009 | 12:00 PM
Flash319's Avatar
Ya, could be your sending unit is leaking by showing a bad reading.
Old Apr 26, 2009 | 12:55 PM
what should the psi be ?
Old Apr 26, 2009 | 02:53 PM
desert-rat660's Avatar
mine always has better oil pressure when its cold, once it warms up it drops a bit when im driving
Old Apr 26, 2009 | 04:00 PM
myyota's Avatar
It sounds like the sending unit is bad.
bigjstang
Jun 2, 2025 03:56 PM
jbv808
Aug 6, 2021 04:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
88yodabasket
Jul 13, 2015 01:32 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
