LOts of pics 3vze rebuild
Old May 31, 2009 | 01:52 PM
Justinlhc's Avatar
That motor looks like it's about to go another 300k worry-free miles at the minimum.
Just curious because I'm not as far advanced as you appear to be, what are you doing with the valves and that plunger thing? I've never seen anything like that. I had the machine shop handle all that stuff when I did my heads so I'm kinda clueless.
warmonger88's Avatar
it looks great, i wish i had the time to spend on mine like you did, i might just rebuild another one , just to have for a abackup, and i think i'll go about the same route you did.
Old Jun 1, 2009 | 06:44 PM
RMA's Avatar
RMA
Originally Posted by toyospearo
OH MAN!! That looks complicated.
Nice work!!
Great looking motor!
THanks !!!!
Originally Posted by KarenCaren
Oh nice. What an awesome job you did. I sure hope you did some video on how you accomplished that so we can watch and learn. Thanks for sharing the pic.
__________________
If you ain't first your last!
mazda parts
NO No video , I havent installed it yet and dont know if I am .
Originally Posted by Quickywd01
Can you explain what was done at the machine shop please because I don't see it in your sig?
I know I wasnt very clear that was about my 89 2wd pickup but I changed my signature a bit.
I am lapping the new valves to the old seats with medium and fine grit.
Old Oct 28, 2010 | 04:27 AM
ej1bullet's Avatar
look at this one ..
This package includes:
Full Gasket Set
Graphite head gasket
Intake manifold gasket
Exhaust manifold gasket
Valve cover gasket
Viton valve stem seals
Camshaft seals
O-rings, Seals
Oil pan gasket,
Front seal
Rear main seal
Oil seal and other small gaskets
Head Bolt Set
Oil Pump
Water Pump (comes with Outlet Pipe)
Freeze Plug
Complete Belt Kit
Timing Belt
1 Tensioner (made in Japan)
1 Idler (made in Japan)
Pistons With Complete Ring Set (available in Standard Size and Oversize 0.50mm = 0.020" )
Premium Steel Material Chrome Piston Rings
Ring size 1.5x1.5x4.0mm, Bore diameter 87.50mm, Compression Ratio: 9.3:1
Engine Rod Bearings, Main Bearings, Thrust Washers (available in Standard Size and Oversize 0.25mm = 0.010", 0.50mm = 0.020", 0.75mm = 0.030" )
all for US $395.95 and free shipping what you think??
http://cgi.ebay.com/ebaymotors/93-95...item3a5350e6b4
Old Oct 28, 2010 | 04:32 AM
  #25
ej1bullet's Avatar
by any chance do you still got the part no. for the knock sensor wire ??
Old Oct 28, 2010 | 04:56 AM
  #26
Lysmachia's Avatar
Fantastic set of pics. Subscribed!
Old Oct 28, 2010 | 05:37 AM
  #27
Wrenchinjoe's Avatar
Nice work! The pics are very helpful, thanks for posting that
Old Oct 28, 2010 | 05:40 AM
  #28
bryan89's Avatar
The motor build looks pretty nice. Should last long enough for your son to drive it. which would be cool cause he helped build it.
but, a little post jacking if you dont mind. ill be quick.
Do you have a link to a write up or more pictures or something for your sub enclosure? That looks really sweet stuck in the side compartment there.
Old Feb 20, 2011 | 09:49 PM
  #29
norcal707's Avatar
hi there, I was wondering if you have this done because I am wondering how you like this rebuilt kit from ebay...I am thinking of buy one to rebuilt my 3vze engine during the summer. thanks
Old Feb 21, 2011 | 04:17 AM
  #30
phildelfino's Avatar
Originally Posted by RMA
I am working on a dual battery set up.
I hope you document this aspect of your setup. I would love to see parts list and everything.
Old Feb 21, 2011 | 01:30 PM
  #31
RMA's Avatar
RMA
well some have had bad luck with them .. ive had good luck with them ,used them 3 times and so far so good this engine , my wifes 94 and one other ,all are still doing ok .
the 4runner this rebuilt engine went into is getting a paint job right now ,i'll post some pics of it when its out and anfd about.
Old Feb 21, 2011 | 01:31 PM
  #32
RMA's Avatar
RMA
i dont remember if i posted it on here or not.. all i used was an isolator i bought of ebay .. was pretty simple .
Old Mar 13, 2011 | 05:34 PM
  #33
MrWheeler's Avatar
Engine Swap Question.
The pics you posted are great. I took a lot myself because I am swapping out mine with a reman.
I have the old engine out and sitting next to the new core. I'm a little lost at this point, I bought the factory set of FSM, but am having problems finding where it would guide me through assembling the new core.
My biggest questions are on what to put on the gaskets and best procedure as I switch stuff over. What keywords/sections should I look for in the books?
What type of stuff(silicon or other) should I put on gaskets?
Anyway, thanks for your post,
Martin
Old Mar 13, 2011 | 06:27 PM
  #34
streetlancer's Avatar
Great Pics!! These will definitely help on my 3.0 Rebuild.
So how has the ebay kit been holding up?
Old Mar 16, 2011 | 09:42 PM
  #35
RMA's Avatar
RMA
Thanks !!
Well still ok .. have a oil leak at the rear of the driver valve cover but everything else is ok.
bigjstang
Jun 2, 2025 03:56 PM
jerusry
Oct 19, 2015 05:28 PM
smiley52
Jul 11, 2015 05:16 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
