Loosing Oil??
Old Jan 18, 2010 | 03:29 PM
1990yota-pickup's Avatar
better step up to some 20/50 or some 15/40 Rotella
Old Jan 18, 2010 | 03:30 PM
ibeamtaco's Avatar
i run 20-50 normally but on the first 500 miles after bottom end or head work i run 10-30 and always valvoline and yeah i change oil at 500 miles past any internal work and during that time i ck for loose bolts and crap i overlooked or stuff that loosened up
i will always burn some oil in the first 3K but like i said i have seen it take up 2 8K
you can try to put some a/c die in oil and look around for the neon green color a black light really makes it shine but if you are loosing oil and its not leaking its burning so u haven't broken it in yet or rings are not in right maybe upside down
Old Jan 18, 2010 | 03:41 PM
you sure do know your stuff..
Old Jan 18, 2010 | 03:46 PM
TORTIS's Avatar
did you offset the rings when you installed them?
  #25
ibeamtaco's Avatar
i have torn the yoters down so Manny times also my dad has ben a wrench my hole life and owns a shop in San Diego that i managed for 2 years before i moved out to AZ so i got to learn a lot growing up but I'm all over the form because I'm sick so just hanging out on comp i have posted like 6o times since yesterday hahah
forum*
Old Jan 18, 2010 | 03:51 PM
  #26
forum*
i've been off work sense early friday morning dont go back to work until wed... just been setting around ... doing nothing ..
Old Jan 18, 2010 | 03:56 PM
  #27
hope you didnt install the ring up side down.. did you stager (off set each set of rings)
Old Jan 18, 2010 | 05:49 PM
  #28
Teuf's Avatar
Check this article out, sorry no link, about oil...... ( Ferrarichat.com )--Dr. Ali E. Haas, its some good info on oil.
Thanks
Old Jan 18, 2010 | 06:00 PM
  #29
Teuf's Avatar
http://www.ferrarichat.com/forum/faq...=haas_articles
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
TJWilly
Jul 31, 2015 02:05 PM
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
calderp
Jul 27, 2015 09:58 AM
