Loose shifter guild pins
Old Dec 13, 2012 | 06:57 PM
timothy47129's Avatar
First off some how i spelled the tilte wrong should have been guide. anyway I have a very sloppy as in moves 2 inches in gear shifter. So I replaced the upper bushing which helped some.but now need to replace the lower seat. I had a spare housing with lever in the garage so I disassembled it to inspect the seat in it and found the guide pins the shifter ball slots fit into loose due to the steel pins wearing out the aluminum.when I held them in tight the play was 1/2 of what it was.so I had been reading were some people have found them broke off an replaced them with ground down bolts.so I grabbed some hardened bolts I had laying around that had that were just threaded on the end and were the same size the pins were and used them.the pins are smaller were they go through the housing so I drill the housing the same as the large end of the pin and cut them to length and pressed them in and it worked out perfect I just have to wait to get my lower seat to try it out.does anyone see anything wrong with this fix?i will post some pics
Old Dec 13, 2012 | 07:27 PM
here are the pics http://s777.beta.photobucket.com/use...yota%20shifter
Oh and they are pressed in so tight you cant turn them by the bolt heads
Old Dec 13, 2012 | 11:51 PM
erock13's Avatar
If it works and is solid and not coming out, i see no problem with it..
Old Dec 14, 2012 | 02:20 AM
junkpile's Avatar
I did a remarkably similar fix several years ago. You shouldnt have any problems.
Old Dec 15, 2012 | 05:04 PM
If your fix has lasted for several years thats good enough for me.It sounds like it will hold up well for me.Thanks for the input.
mwisham
May 26, 2021 02:51 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
irv
Sep 22, 2015 11:51 AM
