lockright or leave open?
Old Mar 7, 2009 | 05:38 PM
ffryno13's Avatar
i have a lockrite in the SFA and a spool in the rear i use my truck as a DD but i drive to the trails everyday. and i am running 37s never once had a problem with it at all i say use the lockrite in front and call it good and get your ARBs later.
Old Mar 8, 2009 | 05:24 PM
TOYOTA 1's Avatar
thanks for the info!
were you ever hard on it? like full skinny petal on some nasty hill climbs hard?
Old Mar 13, 2009 | 01:36 AM
ffryno13's Avatar
um not any super nasty hills but everything around here is red clay so it depends on the weather if you get traction or not. if its rained then say bye bye to traction if its been dry bring extra birfs and inner axles. both of which i have had to do on the trail. but i ve loaded the snot out of my axles stuck between rocks and never had anything break the clutch slipped a bit that was all. when i broke before i was being dumb and tried to crawl straight up a rock face just messing around. very embarrassing. i broke birf once but it was getting ready to go anyway and i was planning on it breaking
Old Mar 13, 2009 | 07:37 AM
Beaniam's Avatar
I have an aussie in the HP third in my sfa and run 35's and 38's. Have not had an issue and It's not an issue on dry pavement with the hubs locked either. It unlocks and ratchets just like the rear end does when rolling around a corner. I've driven it a couple it times in the ice and snow on the road with the front end locked in and it didn't kill me. You adjust accordingly with your driving style and get used to it fast.
Old Mar 13, 2009 | 09:17 AM
  #25
TOYOTA 1's Avatar
it cant be to weak then lol.. what part of Oregon is banks located in?
thanks for the reply!!
once again, are you hard on it? or just crawl around?
anybody else with big tires and a lunch box locker want to share there experiences??
Old Mar 13, 2009 | 09:20 AM
  #26
algranger's Avatar
Originally Posted by TOYOTA 1
but in most situations a open front end is easier on parts is it not?
Very true. I'm open front on 35's and theres some spots I made it through easier than my buddies fully locked on 36" tsl's. They had a really hard time turning around cause their trucks didnt want to actually turn, mine however basically spun in place.
I think i'm gonna go selectable in the front too cause i dont think i wanna weld it for that reason^^ and i really dont want an autolocker for obvious reasons.
Old Mar 13, 2009 | 09:36 AM
  #27
Beaniam's Avatar
I am hard on it however it's south Jersey. No rocks around here. Sand, mud, hard pack, and washouts.
Old Mar 13, 2009 | 09:48 AM
  #28
TOYOTA 1's Avatar
yea I'm not much of a rock crawler either..
i love obstacles though! but instead of rock, we have really tight off camber muddy trails with stumps and old logs that are half buried in the ground. and lil rock here and there.
oh, and the Oregon dunes
Old Mar 13, 2009 | 11:47 AM
  #29
algranger's Avatar
Sounds like washington. I moved here from Utah the wheeling is way mroe fun here
Old Mar 13, 2009 | 12:02 PM
  #30
ffryno13's Avatar
35 miles west of portland on hwy 26 and 25 minutes away from Browns camp. so i got a bit of a wild hair this morning and thought man maybe i should really just stomp on it and see how it goes. well i have the lock rite in the front and spool in the rear. i found a decent hill and stood on it i went side to side but never backward. i went up a section of powerline trail it was kinda sticky outside but not to wet. and there weren t any large obstacles in my way smaller loose rock biggest i d say is about 6". hope that helps
Old Mar 13, 2009 | 12:10 PM
  #31
904_runner's Avatar
Hey im running a lockright, it is in the rear of my 4runner, and a detroit ez locker up front..
I am also running 36" tsl sxs and i love both lockers..
Ive had the lockright for a while now. Probably a year or so now..
I have not had a problem with it so far..
and as far as having an auto locker up front, it isn't so bad...
Much better than open IMO..
Old Mar 13, 2009 | 02:25 PM
  #32
TOYOTA 1's Avatar
thanks for the replies guys!
I'm leaning toward just using the lock right. i mean i already have it, and i got a good deal on it, so why not lol.
next time i get stuck because of my open front end, ill put the lock right in.
shouldn't be to long
runnermedic
13
Sep 21, 2015 05:20 PM
mat
Sep 17, 2015 11:18 PM
bhaithc
Sep 17, 2015 07:53 PM
LotOMiles
Sep 14, 2015 11:45 PM
--Oz--
Sep 6, 2015 01:06 AM
