Locking Hub Issue
Old Aug 7, 2020 | 11:40 AM
dsh's Avatar
dsh
Locking Hub Issue
Hello I have a 94 IFS with Aisin locking hubs.
After my last wheeling trip, I unlocked the hubs and got back on pavement. I heard a hum only around 40mph, and the sound continued even in neutral. After some looking, I realized that even though the passenger side locking hub was set to free, the CV axle was still locked. So I'm about to take it apart and see what I find. Just wanted to ask around first to see if there's anything I should look out for. Also, since the hub is still locked when set to free, after I disassemble it, should I re-assemble it with the hub set on locked?
Thanks for the help everyone.
Old Aug 7, 2020 | 03:37 PM
wallytoo's Avatar
whether the hub is locked or unlocked plays no role in reinstalling it after servicing. it isn’t magic, it’s only a mechanical connection. the only moving parts are in the hub, not on the cv stub.
it’s possible a spring inside the hub is broken, causing it to fail to freewheel.
Old Aug 9, 2020 | 07:19 PM
muddpigg's Avatar
Pull it a part. A little water gets in or too much grease an both keep hub from unlock.
If water got in then look at wheel bearings too.
Old Aug 12, 2020 | 12:27 PM
dsh's Avatar
dsh
Got it apart, cleaned and greased everything and now it's all gravy again.
It looks like the previous owner didn't have a gasket so used some rtv sealant that got in and gunked up the spring a bit.
Old Aug 12, 2020 | 01:30 PM
Blueman's Avatar
Most mechanics I know curse RTV like The Plague.
Old Aug 13, 2020 | 02:13 PM
muddpigg's Avatar
I'll use RTV on a gasket but not by itself, never seems to last long.
I had a helluva time tracking down leaks into locking hubs. went through several wheelbearings. Finally found problem someone smacked locking hub with a BFH and deformed metal on mating surface. filed it down and no more issues.
barrel roll
Sep 8, 2010 03:01 PM
a4runnerfreak
Jul 31, 2008 10:30 AM
dcmbsc
May 10, 2008 06:33 AM
jagger_snitt
Jan 26, 2008 12:42 PM
wailukutoy
Mar 23, 2006 06:02 AM
