Locking Brakes
Old Oct 13, 2010 | 02:32 AM
Ride4Fun's Avatar
Locking Brakes
I'm not sure were to put this, but I know that I need help.
I have a 93 4Runner (see below) with a mix of parts and I am having brake problems. The brake booster and master cylinder are both 97 and I have disc all around. The problem is - the passenger front caliper wants to lock up. I've swapped calipers and still no solution. I have been told that the problem could be in the master cylinder and/or the proportioning valve. I'm I correct in thinking that the proportioning valve is built into the front end of the 97 master? The master has a 10mm bolt on the lower front section and when loosened it tends to release the lock on the caliper - does this mean that the problem is in the master itself?
Any help with this would be greatly appreciated. Thanks in advance.
Old Oct 13, 2010 | 08:55 AM
WesinTX's Avatar
The rubber lines going to the caliper can callapse internally and cause this, it makes the act like a check valve. Flow into the caliper but no flow out. If it was the master I would think it would be doing it to both front brakes and not just on.
Jun 1, 2021 01:51 PM
westonian18
May 1, 2020 06:38 AM
okamikai
Apr 30, 2018 10:19 PM
Sr5crawler
Jul 31, 2015 12:32 PM
Johntom240
7
Jul 13, 2015 12:18 AM
