Like I Need Another Project...
Old Jul 21, 2009 | 08:50 PM
  #101
shancerlelby's Avatar
i own a turbo dodge. i have changing head gaskets down to an art 6 different cars over the last decade. Oddly i just never have to work on my truck other than change the oil and maintenance stuff.
Toyota has spoilt me.
Old Jul 23, 2009 | 05:58 PM
  #102
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
Got the heads back today. I need to go back and ask specifically how much he took off of them. He didnt say it was alot but he did say it wasnt a little. I'm thinking the block might need some help. Yall think I should worry about getting a thicker head gasket?
Old Jul 23, 2009 | 06:03 PM
  #103
toylocost's Avatar
Oops. Forgot the pics.
Oh yeah... He said the valves were all GOOD.
Old Jul 23, 2009 | 09:18 PM
  #104
bigtrucknwheels's Avatar
those look like a million bucks....
Old Jul 24, 2009 | 09:52 AM
  #105
toylocost's Avatar
So I checked the block the only way I could. Thickest, straightest, heaviest, steel ruler I could find. I couldn't get the .006 feeler gauge through anywhere. Im guessing the block is ok.
Sooooo, off to go scotch brite it and throw them heads on. Cant think of anything else to do before torqueing the heads down other than turning to TDC????
Old Jul 24, 2009 | 09:54 AM
  #106
toylocost's Avatar
OK, just had another idea (great), wonder if I should bolt the manifolds and crossover up to the heads and put them in the same way they came out?
Old Jul 24, 2009 | 02:15 PM
  #107
toylocost's Avatar
I hope thats clean enough. I can feel that they arent perfectly smooth. But they are pretty good?
Somebody say something. I hate talking to myself.
Old Jul 24, 2009 | 05:26 PM
  #108
toylocost's Avatar
So all the ratchet are getting set the other way and I'm breaking out possibly my favorite tool, the Snap-on torque wrench.
29ftlbs Seems a little low for exhaust mani... oh well... thats what it says in the FSM.
Old Jul 24, 2009 | 06:37 PM
  #109
RMA's Avatar
RMA
[/Quote]Somebody say something. I hate talking to myself.[/QUOTE]
HAHAHA!!!! I feel the same way , I am in a little corner of yotatech nobody ever visits .
Dude just make sure you dont feel anything on the heads , use some laquer thinner on there also.
When you do the valve adjustments , if you need any shims let me know I have a few laying around and may have one you need .
I think I could ship one or two your way with a couple of stamps so no big deal.
Old Jul 24, 2009 | 09:06 PM
  #110
toylocost's Avatar
How bad do you think I need to adjust them? I work at Toyota so I can probably get the shims no problem. Thanks for the offer though, stuff like that makes me more willing to help you in the future.
Anybody know what this thing is called? I dont believe ENGNBLDR sent me a gasket for it...
And look at this... You can see that the old gasket has some type of inner crush ring that the new one doesnt have. Should I worry?
ExManis are torqued to the heads, crossover is finger tight, heads are torqued to 33ftlbs. They still need to be turned the extra 180 degs.
Used a white-out pen to mark the head bolts before turning them their two 90 degree turns. Worked very well. (I think my macro setting is broke, its useless)
Last edited by waskillywabbit; Jul 31, 2009 at 05:20 AM. Reason: Inappropriate Language Removed
Old Jul 24, 2009 | 11:57 PM
  #111
woo hooo lookin killer. i woulda threw in some encouraging words but i just cant keep up i guess! your gonna really have to steam clean that engine bay after all this to match those purdy heads!
Old Jul 25, 2009 | 12:20 AM
  #112
RMA's Avatar
RMA
the first pic is of the #1 water By pass pipe you seal it with FIPG and torque the nuts 6.9 N-m (61 in.-lbf) and the bolt to 4.9 N-m (43in.-lbf).
And I did not know you worked at toyota , I guess that makes a difference when Needing parts.
Old Jul 25, 2009 | 06:32 AM
  #113
TNRabbit's Avatar
Good Job! That was one helluva nasty-@$$ engine~
You ARE going to replace both the idler pulleys, RIGHT?!?
Old Jul 25, 2009 | 05:43 PM
  #114
toylocost's Avatar
Thank you very much for that explanation.
It does help especially if I need to ask the mechanics about something. But parts are still expensive even with the discout. haha
Uhhh, yeah mine are absolutley screwed. They barely spin. lol
Old Jul 26, 2009 | 08:23 PM
  #115
toylocost's Avatar
Originally Posted by Tubbyfatty
That looks nasty inside lol. for plugs, I hear the NGK v or g powers are perfect. 2.50/3 a piece.
Whats the difference between V or G powers? I like that price alot.
Old Jul 26, 2009 | 08:45 PM
  #116
toylocost's Avatar
What are these things the injectors sit in? Can I clean them off and re-use them? I think Toyota wants about 6 bucks a peice for them.
Old Jul 26, 2009 | 09:21 PM
  #117
92silverrunner's Avatar
Im sure you can i reused mine and they worked fine,they are used to seal the injector in the manifold so u dont loose vacuum.cant remember the specifice name for them.
Old Jul 26, 2009 | 09:23 PM
  #118
Btw, your build is coming along nicely cant wait till it is running.
Old Jul 28, 2009 | 08:57 PM
  #119
toylocost's Avatar
Thank you. I sorry I didnt see this earlier. This is the second time it hasnt bumped this to my subscribed threads when someone replied.
Today I got my order in...
Air filter
Knock sensor wire
A/C belt
P/S belt
Fan belt
Timing belt
Water hose
T-stat
T-stat gasket
Wires
Cap
Rotor
6 NGK V-powers (upon reccomendation by Tubbyfatty)
Oil filter
drain plug gasket
5 quarts of oil
Water pump will be here tommorow
I realized I forgot to get coolant so maybe grab that and some assembly lube.
Old Jul 28, 2009 | 09:04 PM
  #120
Air filter
Knock sensor wire
A/C belt
P/S belt
Fan belt
Timing belt
Water hose
T-stat
T-stat gasket
Wires
Cap
Rotor
Oil filter
drain plug gasket
5 quarts of oil
what about the oil filter dude??
nice work, I like the can-do attitude
