level of importance
Old Mar 23, 2009 | 06:14 PM
  #41
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Ok, the Aussie is $239, so not that much less than the Lockright. I had thought it was less in price, just didn't know how much.
Old Mar 23, 2009 | 09:20 PM
  #42
904_runner's Avatar
Originally Posted by John101477
yeah i'll probably go with the TG to but i'll make my own changes.
Mike your rig is lookin good!!! I was out at Butte today. they have a few things happenin out there with two new buildings and the solor system going in.
Thats where i go... Shoot idk how often you are out there or what, but im out there everyday, you would have seen my truck if it was running..
Old Mar 23, 2009 | 10:59 PM
  #43
Matt16's Avatar
Locker most definitely.
An Aussie or LockRight would be great with the auto. Your risk of "spinning out" is only a problem if you drive on really bald or wide mud tires on ice or snow. That chance can be further eliminated by putting it in 4wd when it gets really slick.
I did a really (!!!) detailed quasi-blog about living with a locker. See my signature or search Aussie Locker Review. Most of what is said is applicable to all lockers.
Old Mar 25, 2009 | 10:26 AM
  #44
John101477's Avatar
well i ordered the aussie yesterday from payless and apparently there is a 3 week back order on them and thats ordering direct from aussie go figure. I also ordered the TG sliders.
Mike, I only go out to Butte when I have to, but all the temp fencing around the Arts building is what I used to do. I was supposed to buy the company but i got jacked out of it because the owner needs cash now because of a divorce. I am only working now when there is fence instead of full time until it sells. there are some nice yoats out there. seen a gal drivin one in the upper parking lot monday, she was a little hottie!!! LOL
Old Mar 25, 2009 | 10:38 AM
  #45
904_runner's Avatar
OH you jerks with your solar pannels taking out half that lower parking lot!
LOL...
Hopefully mine will be back in a few days...
Old Mar 25, 2009 | 11:37 AM
  #46
Junkers88's Avatar
Wise choice. The three week delay is a little odd IMHO but it'll give you time to get the sliders welded on. Be sure and post up pictures so I can drool over the armor that I can't afford yet.
Do you plan on installing the Aussie yourself?
Old Mar 25, 2009 | 11:44 AM
  #47
904_runner's Avatar
Man i missed that,.
You will like the sliders...
Old Mar 25, 2009 | 02:42 PM
  #48
John101477's Avatar
yep i did block it all off lol but now you'll have covered parking lol
Ok hahhaa i decided that the budbuilt skid plate was wayyyy to expensive for the amount of work to make one or have it made haha. so i stopped off at this welding shop and whalla 50 bucks later, i'll have 3/16 in plate bent where i measured and ready to go. all i have to do is drill the holes for bolts. man i tell ya the etching on the budbuilt must cost a fortune!!! hmmm i put in 45 min of work to measure and draw up the plan and save $200
Old Mar 25, 2009 | 02:44 PM
  #49
John101477's Avatar
I do have to install the aussie and i am a bit paronoid about that as i am NOT a wrench!!! but the guys at payless said they would walk me through it if i needed.
Old Mar 27, 2009 | 10:02 AM
  #50
John101477's Avatar
well I got the front skid plate done here are some pics of it before and test fit
Old Mar 27, 2009 | 10:04 AM
  #51
John101477's Avatar
It is painted and in place now. 3/16 thick and the 1 inch angle iron supports should do the trick. I also designed it so that i could add further in the future. the steel, cuts and welding by Brown's Welding in Corning for $75. He is also going to mount the Trail Gear rock sliders for me. because I do not have a BL and the frame sits really high under the body, i will have to angle it down slightly off the frame and then angle back up to about 3/4 of an inch below the body and tilted back up.
the Rock sliders will probably get put on tomorrow.
Old Mar 30, 2009 | 04:24 PM
  #52
904_runner's Avatar
I nothced the bottom of the body a little. On that pinch weld.
The aussie install isn't that hard.
Check out gearinstalls.com
Zuk has some really good writeups..
Old Mar 30, 2009 | 05:42 PM
  #53
John101477's Avatar
what do you mean pinch weld? term i never heard before lol.
well saturday i got the TG sliders in place. Kenny over at Browns decided against the angle and added several steel plates to drop it 3/4 in below the body. and then angled the slider up to keep it inside the tire line. it really turned out good. I ran out of roll-on bedliner, so tomorrow i have to buy some spray to finish it all up. I worked on the sub enclosure today. The old enclosure was simply to big at 4.5 cu.ft. w/ a 4in port so I disected my old enclosure down to 1.6 which will give me a 1.5 sealed after speaker displacement. hope to have that done tomorrow, we'll see....
Old Mar 30, 2009 | 06:20 PM
  #54
John101477's Avatar
here is my sub.
Big Little Bear
230
Nov 13, 2023 11:42 AM
beebeeri000
Oct 2, 2015 10:42 PM
charlie_fong
Sep 27, 2015 10:06 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
Dparr2ndgen
Sep 8, 2015 01:06 PM
