Letter and number stamped on my 3vze pistons
Old Jun 15, 2018 | 02:21 AM
Aure's Avatar
Hi everyone,
I am rebuilding a 300k 3vze engine and just got confused to choose the right rings because I noticed that each pistons is stamped with a number 2 and a letter B on top of it. Each rod has also a number 2 stamped on it.
I know there is 3 different grades of Pistons/rings and bores for this engine but I can’t found anything precise about it.
Most of aftermarket rings are std or over sized.
Anyone had this before?
Old Jun 15, 2018 | 07:02 PM
millball's Avatar
duplicate
Old Jun 15, 2018 | 07:05 PM
millball's Avatar
Those numbers are for perfect selective fitting new, at the factory, and mean nothing afterwards.
No such parts are available aftermarket, and I suspect that such were never available as spares from Toyota either.
If the bores are standard, standard rings will be correct. Most standard rings accomodate up to .010in oversize.
If the block has been bored, the appropriate oversize pistons and rings must be fitted, of course. Precision measuring instruments are your friend.
Old Jun 16, 2018 | 04:31 PM
Aure's Avatar
Awesome, Thanks for that! I am feeling better and confident now.
I checked Pistons, cylinders, clearances, all is within specs and you just nailed it. Thanks again
bob nob
Mar 5, 2019 04:44 PM
derockus
Oct 18, 2012 10:04 PM
Stangmandan
Apr 23, 2010 04:55 AM
leiniesred
Sep 14, 2006 06:00 PM
