LEDs in Dome/Cluster/etc.
Old Oct 30, 2009 | 10:41 AM
  #41
stock as possible's Avatar
and you've had them in for a while now too, haven't you? Did you get different color lights for the different indicators? Green for turns, blue for high beams, red for break, etc?
Old Oct 30, 2009 | 12:03 PM
  #42
Jay351's Avatar
I have had them for over a year now
Blue leds for everything I mentioned
The turn signals are too bright, there I would use a regular bulb, or something less powerfull than the WLED x5. Once you open the cluster and look at the green plate around the turn signals that you have to remove (or it will tint your lights green, stock turn signal bulbs have no condoms) you will understand.
The only ones I would not do again, is the hi-beam indicator (came out too bright!!) and the brake light. Only reason for the brake light is the blue bulb is alot dimmer in that area. If I ever have the cluster out I will change it out, but its not a big deal.
Old Nov 1, 2009 | 07:39 PM
  #43
N2Frodn's Avatar
I got tired of the DIM/OFF/FLICKER settings on my dome light. The metal contacts in the switch are the cause of the problems, they wear out over time and nothing I have tried has fixed it. Even purchased a couple of boneyard ones, they all were problematic.
Grabbed an 8 LED array out of the pep boys "Ricer" part section and a 3 way toggle switch. Took one of my spare light housings and gutted it, dremeled out the center to fit the switch and the LED array in, soldered wires onto the door and on ground contacts and the power lead.
Now I have a nice, bright dome light that works perfect. No more digging out my flashlight to find stuff inside my truck.
The only downside is that it is really, really bright. I might add a small red or amber light somewhere in the truck for those times I am driving and need to see something without screwing up my night vision.
If I remember to, I will snap some pics of it for you guys.
Old Nov 1, 2009 | 11:29 PM
  #44
Monochrome's Avatar
Originally Posted by stock as possible
Did you get the WLED xHP5 or just the WLED x5. The HP's have a 360 degree spread but I'm wondering if they would be too bright for the interior, they are SMD, does that mean anything?
I got the standard WLED x5, non HP. Hopefully that won't be too bright.
LEDs come tomorrow. Will probably start this project in a few days though, I have other wiring issues to attend to, and another coat of paint.
Old Nov 29, 2009 | 11:53 AM
  #45
Did you ever get those lights installed?
Old Nov 29, 2009 | 06:44 PM
  #46
Blue Bowtie's Avatar
Good info man, I've been wanting to do this for awhile now.
Old Nov 29, 2009 | 09:14 PM
  #47
86 TOY's Avatar
Waiting on some pics... lights in yet?
Old Nov 29, 2009 | 10:54 PM
  #48
stormin94's Avatar
Interesting idea.
I'm not sure I like the green dash lights. It's just too bright for me.
I like the look of the climate control lights, though. But they seem obnoxiously bright. I can't see well at night, and bright lights in my eyes wouldn't help.
I'm not trying to criticize. Just my opinion. I think it looks good, though.
Also, I like the idea of LED dome lights, and replacing the red marker lights in the doors. If I keep my doors open for too long, it drains the battery.
Anyone done this?
If so, how bright is it?
Old Dec 7, 2009 | 12:48 PM
  #49
Monochrome's Avatar
I've been MIA from the forums for a while, sorry for that! Had to catch up on life for a bit.
I've installed the dome lights and a few of the interior lights but haven't done the justice of a good write-up yet. So, be patient. And I think it looks pretty damn good. The dome light has made a huge difference, it's WAY brighter. Not too bright though. I'll take some pics. It's also a good thing that I got the 3-way LEDS, because the light is distributed quite well.
Will folluw up later...
Old Dec 7, 2009 | 08:32 PM
  #50
shaeff's Avatar
I did my dome light and cluster like, three years ago. Never had a problem with any of them. Mine are red. I think I posted some crappy pics somewhere...
Old Dec 11, 2009 | 03:40 PM
  #51
ripcurl329's Avatar
Im in the process of doing this, just bought a cluster w/tach off ebay for only $15. getting ready to order from superbrightleds.com. I think im going to try the red ones. Ill have to take some pics as i go. tonight im going to start clean put the new cluster.
-Steve
Old Dec 11, 2009 | 09:29 PM
  #52
rustosaur's Avatar
Originally Posted by Monochrome
Yes, you can swap the cluster, but I want the original cluster with the 270k+ miles on it. I do have an aftermarket tach, but I find that I almost never use it anymore. I just know when to shift...
Glad to hear you like the dome and license conversion! I hope I will. And I don't have pics yet, but the LEDs should be arriving early next week.
This is a late comment, but for what it's worth, you can probably swap speedo mechanisms between the SR5 and non-SR5 cluster. I used to do that on Supras, celicas and corollas all the time to keep the mileage accurate when changing clusters for repairs or lighting mods.
Old Dec 17, 2009 | 08:58 PM
  #53
carter_SR5's Avatar
New here but while we're on the topic of LEDs...
you guys seem to complain or worry that they'll be too bright...my truck has the dimmer switch/dial. Does the dimmer not work as well when using LED's? Thus becoming an issue?
thanks
Old Dec 18, 2009 | 07:32 AM
  #54
joeynational's Avatar
thanks
you can't dim these type of LEDs
Old Dec 18, 2009 | 12:55 PM
  #55
shaeff's Avatar
Yes you can, just not with the crappy dimmers that Toyota put in these trucks. I have the dash in my MKIII Supra all done with LED's, exactly the same as my truck. They dim down exactly like the stock bulbs do. The stock dimmer in my Supra is way smoother/better quality than the ones in these trucks.
I think the 4runner dimmers are better than ours, but that's just by feeling it- I never actually tested them.
Old Dec 18, 2009 | 01:18 PM
  #56
carter_SR5's Avatar
Is there a kind of LED you can or are all LED's like that? or do you have to just stick with a red 194 bulb if you want the dimmer to work?
-edit i guess i was too late lol
Old Dec 19, 2009 | 06:23 PM
  #57
Jay351's Avatar
My LEDS dim almost 80% then they just turn off. They still dim.
Old Dec 23, 2009 | 06:09 PM
  #58
H03Runner's Avatar
alright, i probably missed this because i'm in a yota tech daze from looking at all the forums, but which bulb am i supposed to use for my gauge cluster? 194 or 74? and has anyone had any dimming problems with the SMD or SMT bulbs compared to regular LED bulbs?
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
RyanJ989
11
Apr 7, 2021 09:41 AM
voiddweller
Sep 28, 2015 11:21 PM
Scotttekoch
Sep 28, 2015 10:30 PM
dropzone
Sep 13, 2015 11:18 AM
