Leaky thermostat housing - missing gasket?
Old Jan 20, 2021 | 06:23 PM
Luca Signore's Avatar
5 Year Member
Hey guys -
I replaced my thermostat when I did my timing chain a few months ago and I recently noticed a lot of crusted up coolant around my thermostat housing. The housing is torqued properly to 13 ft/lbs, but I'm still getting this leak. When I replaced the thermostat, the new one did not come with any sort of gasket. The old one did have a little o-ring type thing that went around the thermostat. I reused that since I had no other alternative in that moment. Is this just a matter of getting a new o-ring like this one?
Or is there an actual gasket for the housing?
Thanks!
Old Jan 20, 2021 | 06:42 PM
RAD4Runner's Avatar
That o-ring is it. Maybe the old one had gone stiff.
Old Jan 20, 2021 | 06:49 PM
5 Year Member
Yeah I remember it felt like a potato chip when I pulled it off. Ok - new one it is! There's no RTV or anything else that's supposed to go there, right?
Old Jan 21, 2021 | 01:57 AM
arlindsay1992's Avatar
If everything is pretty and fresh with no corrosion, the o-ring is all that is supposed to be there. However, typically the surface it seals against is a bit crusty. I always use a thin ring of RTV just outboard of the o-ring to prevent leaks.
Old Jan 21, 2021 | 05:46 AM
5 Fists's Avatar
The same thing happened to me after putting a new thermostat in, got it as clean as I could but kept leaking with just the o ring. A thin application of RTV fixed the issue, just like arlinsday1992 says.
Old Jan 21, 2021 | 11:18 AM
2ToyGuy's Avatar
So far I've been lucky. When I change the thermostat, I clean the mating surfaces to good clean metal, since there's always corrosion/crusted coolant on the lower one, and put a new gasket on. I haven't had any leaks. Yet
Usually about once every 2 years, I replace the t-stat, and it's gasket. I keep the old ones, in case of unexpected problems. I throw out the ones I was keeping before, so my spares are only 1 or 2 years old. Belts, hoses plugs, wires, everything.
Have fun!
Pat☺
chicagopetedagreek1
10
Nov 9, 2017 08:25 AM
chicagopetedagreek1
Nov 7, 2017 02:42 PM
DeadPhish
Apr 15, 2013 08:39 AM
vtruong1
Sep 7, 2008 07:23 AM
skinnyhb
Jul 14, 2008 12:50 PM
