leaky 22re please help
Old Apr 29, 2007 | 10:26 PM
yotaboy66's Avatar
hey my truck just started leaking savagley from the front of the motor like half quart to a quart an hour know the timing chain covers are junk and or what seals could cause this up front or any solutions...
thanks
Old Apr 30, 2007 | 02:27 AM
Rammedic's Avatar
Might want to look at the front crank seal. Is it leaking high on the block or low? Oil pump housing could be leaking. Either way, it sounds like you are going to get to play with the famous front crank pulley bolt.
Old Apr 30, 2007 | 04:13 AM
Buck01's Avatar
I have the same issue. I will be getting a seal and try it out.
Old Apr 30, 2007 | 05:42 AM
YotaJunky's Avatar
If it is the front seal, you may want to look at your harmonic balancer. It's possible that you'll need to add a sleeve and seal to the balancer.
Troy
Old Apr 30, 2007 | 06:33 AM
slamigo's Avatar
don't be surprized when the new front seal you buy is not the same thickness as the one you take out. I bought one from the dealership and it was about 1/2 as thick as the old one. Seems to work though and it was the proper part number. I triple checked.
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
