knocking in engine with acceleration - any advice greatly apprecaited
Old Jun 28, 2013 | 08:29 PM
Meatlog66's Avatar
so ill start with a disclaimer...im only now starting to understand the basics of how an engine works. so if there's a technically bit of explanation, its probably best to just "barney proof" it for me.
So under heavy acceleration, i would hear a metallic pinging near the front of the engine. I've read a couple threads on the topic and decided that its probably that pesky DS timing chain guide. So with the proper replacements, (new TC kit, oil and water pump, TC cover, and new gaskets for everything), i set off to correct "the issue" and save some $$$ doing it myself. The guide apparently isn't the problem...
I'm now lead to believe that it might be a case of spark knock. I've got some of the symptoms,
- using the cheapest gas at the pump
- scorching to the top of the pistons and exhaust valves
- metallic pinging
Any input from a people with more experience would be greatly appreciated.
I will gladly post pictures upon request...
Old Jun 28, 2013 | 08:46 PM
Meatlog66's Avatar
Forgot to mention...
'93 pickup 22re completely stock
Got it from my parents who didn't take the best care of it.
If that helps any...
Old Jun 30, 2013 | 05:55 PM
z31freakify's Avatar
Check your distributor it may be to advance. Do the basics on a complete tune-up, gap spak plugs to specs, might want to adjust your valve lash. If your not so lucky it might be your bottom end knocking and it might need of an overhaul. best of luck
Old Jun 30, 2013 | 06:03 PM
scope103's Avatar
Yup, start at the beginning. Walk through a stock tune-up http://personal.utulsa.edu/~nathan-b...sm/engine.html (look for link to Tune Up Procedures).
Since your engine has a knock sensor, it is very hard to make it knock, even with really cheap gas. Still, no reason not to check timing (and use a timing light, don't guess. They're $20, and you can compare that to what you've already spent on spec.)
Old Jun 30, 2013 | 07:19 PM
Meatlog66's Avatar
everything that ive read on base 2wd 22re's indicate that they dont actually have a knock sensor. toyota for whatever reason didnt put one in; didnt put in the wiring to have one put in later either.
if i had to guess i would dare say it was a timing issue (either too far forward or what have you)...i didnt have a timing gun or anything like that to properly check it when i did an emergency rebuild early last year. but on a positive note, im on a wild "tool acquiring" streak lately...might as well get a Tgun and check/clean/patch everything up while ive got this bad boy torn apart.
heres hoping...
Old Jun 30, 2013 | 08:25 PM
scope103's Avatar
Originally Posted by Meatlog66
everything that ive read on base 2wd 22re's indicate that they dont actually have a knock sensor. ...
So, what DID you read? Any idea why the Factory Service Manual lists a Knock Control Sensor for the 22re? http://personal.utulsa.edu/~nathan-b...ine/9cylin.pdf
(I have a 3VZE, so I have no personal experience to contribute.)
Old Jun 30, 2013 | 09:00 PM
Meatlog66's Avatar
im 99% certain, (because nothing/no one can be 100%) that the only 22re's that come with knock sensors are the 4wd models. mine is just a lowly 2wd model. its supposed to be on the left side of the block, near the oil filter but not to mistaken for the OPS (which even that doesnt seem to want to work with the sr5 cluster i installed...)
even if it is magically invisible, ive decided to just go on without it and finish working on my timing chain assembly, my valve cleaning, and then worrying about get everything put back together. will probably change my o2 sensor while im at it.
Old Jun 30, 2013 | 09:26 PM
Discombobulated's Avatar
Had the same ping and timing wasn't doing squat, tested my o2 and It was fried
Replaced, no more ping
Old Jun 30, 2013 | 10:38 PM
Meatlog66's Avatar
yeah, while after i found out it wasnt the driver side guide being broken, i i started looking at my spark plugs. based on the look of them i came up with either detonation from my timing being set by ear...or a combination of this and my fuel injectors needing a good cleaning. shipped them to Mr. Injector out of Idaho, witch hunter wasnt accepting new shipments so i looked elsewhere.
so im got new NGK V-power plugs (people really seem to recommend this) i cleaned all the carbon deposits off my pistons and im planning on cleaning up the valves tomorrow. i plan on changing out that o2 sensor after everything put back together.
Old Jul 1, 2013 | 01:34 AM
whitecollarredneck's Avatar
This sounds alot like a problem I'm having. Does the noise come back only around a certain rpm range?
Old Jul 1, 2013 | 06:35 AM
Meatlog66's Avatar
its only near the higher end or whenever i drive my truck like a racecar.
i wish i could give both you and myself an actual range, but i lack a working tach or a tool that would give me such a reading.
however if i drive it like a normal human being and shift low instead of the fast and the furious, it doesnt give me too much problem. but its the "what if" that was killiing me
Old Jul 1, 2013 | 06:58 AM
Team420's Avatar
start with a compression test. I'm willing to bet, its time to adjust those valves. A bad o2 sensor could cause it as well.
Old Jul 1, 2013 | 09:54 AM
Meatlog66's Avatar
i wouldnt doubt it need valve adjustments...figured i would take care of that while the engines torn apart. what number would i be looking for when everything is put back together, as far as compression goes?
Old Jul 1, 2013 | 11:07 AM
Gamefreakgc's Avatar
heres hoping...
Harbor Freight has timing lights for $19. Just bought one, works good enough. No excuse not to check the timing since bad timing will cause pinging. Helpful tip though: paint the mark in the pulley (as well as where you want to set it on the degrees meter) white or yellow and it'll be WAY easier to see.
If you haven't already, start reading the FSM like it's your new favorite book. http://personal.utulsa.edu/~nathan-buchanan/93fsm/.
Seriously though, just reading up on sections will solve half your issues. I've learned a ton about my truck and understand it way better. The maintenance section is very helpful, it'll show things like how to adjust valves and other tasks that are more common.
Here's from the FSM about your compression check for a 22RE:
Compression pressure:
1,177 kPa (12.0 kgf/cm2, 171 psi)
Minimum pressure:
981 kPa (10.0 kgf/cm2, 142 psi)
Difference between each cylinder:
98 kPa (1.0 kgf/cm2, 14 psi) or less
Old Jul 1, 2013 | 11:20 AM
Team420's Avatar
170-180 psi is ideal for these motors. But... More important is that all cyl are relatively even, with no more than 17psi difference between them. I wouldnt be happy if there was more than 10psi difference myself.
Old Jul 1, 2013 | 12:07 PM
Meatlog66's Avatar
thanks guys. i made a voyage to HF and picked up and a timing gun, valve spring compressor, o2 sensor socket, and some free screwdrivers thanks to a little old lady who gave me the coupon (and then even got the screwdrivers for me as well.)
thankful the valves werent THAT dirty, should be a quick clean and then im one step closer.
Old Jul 1, 2013 | 01:41 PM
I know this isnt really for helping me, but I'd like to see if thats my problem. I just have a noob question... Where's the o2 sensor and how do I check it?
Old Jul 1, 2013 | 04:10 PM
Meatlog66's Avatar
dont quote me on it...
but if you follow the exhaust manifold down, before you reach the next thing on the pipe (i think its called the catalytic inverter) it should be on the upper side. i beleive its a 3/8 socket.
knocking in engine with acceleration - any advice greatly apprecaited-4997333249_73a496e3a4.jpg
should look like this...(pic belongs to irab88)
Old Jul 1, 2013 | 04:50 PM
Team420's Avatar
should be somehwere befor the cat, and its should be flanged, and have 2 10mm nuts holding it on
Old Jul 1, 2013 | 05:16 PM
j2the-e's Avatar
If it is pinging, you should definitely hear it at low rpm, heavy load, mid-full throttle. Like if you were going up hill when its really hot out with a bed full of sand bags in 5th gear at 40 mph. My old 22re pinged like crazy with low grade fuel. Switched to premium and problem solved. Also: carbon deposits cause higher compression ratios and that can cause detonation as well. Now that the pistons and valves are clean and you plan to use a timing light, you may be ok with regular unleaded.
As far as your sr5 cluster oil gauge issue, did you install an sr5 oil pressure sensor as well? The sensor for your truck is not compatible with a gauge. It is meant for the dummy light
